Question about Cameras
My MX-880 has a significant delay when I press buttons. Takes forever to get going. Turning on the unit is a lengthy amount of time as well.
SOURCE: Frigidaire FDB635RBB heat wash/heat rinse
The "Safe Temp for house hold hot water is between 120 7 125 degrees. plenty good for washing dishes the high temp wash and rinse I've been told was put on the DW's to lessen first year repair calls under warranty. Thus the manufacturer saves lost of $$$ on service calls that just need the hot water temp raised on your hot water tank. DO NOT EXCEED 125 DEGREES WATER TEMP. OR HAVE A PROFESSIONAL REPAIR PERSON CHECK FOR THE PROPER HOT WATER TEMP. ALL YOU HAVE TO DO IS WASH YOUR DISHES NOT USING THE HIGH TEMP,. SETTINGS BUT MAKE SURE YOU DO USE THE HIGH TEMP DRY CYCLE AND YOUR GOOD TO GO HEALTH WISE. This information was told to me by a repairman in the business for 28 years. We have done it and it works just fine.
Posted on Oct 26, 2008
  • 9 Answers
SOURCE: I have a RUDD AC 5 ton and the inside unit is
Is the contacror pulled in? If not check the low voltage to see why it isn't, if it is, check for voltage out the other side with a meter.
Posted on Jul 20, 2009
  • 447 Answers
SOURCE: our kenmore gas range does not properly ignite
The pilot to light the burner(s) is too far away from the burner(s) Allowing the gas to build up before it ignites
Posted on Apr 06, 2010
  • 31 Answers
SOURCE: will not fill up with water before starting
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
Posted on May 09, 2010
Testimonial: "will try, sound good. thanks"
  • 8457 Answers
SOURCE: RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
Posted on May 30, 2010
Having a problem changing channels imputing into MX 3000 remote. Takes about 5 time to react to channel imput.I thought a new battery would help. It did not. Would rebooting the remote in the cabine
Presuming that the IR codes for the 0~9 numbers are captured correctly, then problems like this are usually down to either insufficient time between key presses, which can be solved by adding a small macro delay to each key; or the device being controlled is receiving multiple IR streams either directly from the hand unit and the IR emitters, or there's a blaster in the cabinet that's bouncing IR in multiple paths.
Sep 04, 2014 | Universal Remote Control MX-3000 LCD...
TK 760 scanning delay
Hi Nathan,
Have you tried to stop it from scanning, by pressing scan button?
I hope this helps.
Cheers, Peter
Jan 27, 2012 | Kenwood Radio Communications
My Brother printer will not find an IP on the router. I've tried multiple ports, but all I ever get is zeroes, no IP, but the router works fine, I'm connected to it right now. Everything else thats...
The best way to have this printer work is to connect it with an lan cable. Here are some steps to check if the printer will work again.
Disconnect the lan cable from both ends. Make sure that the printer shows the blue solid light, Try to do the factory and network card reset. First turn off the printer by pressing he switch button on the right side. Press and hold the GO button while turning it on, then press go button 8 times as fast as you can without delay. Once you see the blue light solid again turn off the printer and do the network card reset. Turn off the printer by pressing the switch button on the right side. Press and hold the GO button while turning it on, then press go button 7 times as fast as you can without delay. After 1 minute reconnect the lan cable from the router to the printer. Wait 1 minute again the press the GO button 3 times without delay, it should printer the printer setting page that shows the correct IP address.
Hope this will help.
Feb 27, 2011 | Brother HL-2170W Laser Printer
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
My plotter is recieving info. but takes forever to start plotting.
Try turning the nesting function off. This can save paper when you are doing high volume printing, particularly with smaller drawings but wil cause extreme delays if there isn't a steady flow of drawings going to the plotter.
Apr 14, 2009 | Computers & Internet
Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Dec 10, 2008 | Logitech Harmony 880 LCD Remote Control
Have trouble turning on the machine
MOST all-in-one printers have a time delay on the on/off button.
Try pressing and holding for a second or two and it should start first time everytime.
Hope this helped.
The INK Store
Dec 02, 2008 | Epson Stylus CX6400 All-In-One InkJet...
I know this is probably too easy for you....
look a the settings currently on your camera
turn the knob to full auto and then go to the menu and do a full reset of the unit (see page 100 of manual)
then progressively re-add your custom settings
another option is that you have the shutter set to timer mode
change to 1/multi to repair
Nov 21, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Delay in picture taking
Melzim, another user, is exactly right. The lower-end digital cameras experience a significant shutter delay when using the camera; it's an unfortunate fact.
What you can do, outside of investing in a newer model (which do have improvements over the earlier models) is simply try to anticipate your subject's movement - or concentrate on portraiture, etc.
There is a huge value, over time, in having pictures of smiling families, standing still, believe it or not.
The A85 is simply not the camera to use to freeze action.
Nov 06, 2007 | Canon PowerShot A85 Digital Camera
Shutter delay
If you have installed optional expanded memory, you may notice a delay between the time you press the shutter button and when the camera beeps. You can reduce this delay by pressing the button down halfway, holding it as long as necessary, and then pressing it down the rest of the way when you are ready to take the picture. The reason for this two-step shutter is to save battery power. After a picture is taken, compressed, and written to memory, the Sparc CPU shuts down to save the battery's power. When the shutter button is pressed halfway, the Sparc wakes up and stays in the ready state until the user presses the shutter button the rest of the way. Besides the delay in waking the Sparc, there is a variable delay which occurs prior to the Sparc being in the ready state. This delay is dependent on the amount of free flash memory.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
