Question about York Exercise & Fitness
York Pacer 4500 treadmill Error 1 Problem
Hi, I have a York Pacer 4500 treadmill, I can turn it on but when I try to start up and adjust the speed it displays Error 1 message on the screen and beeps and wont move. Can anyone tell me what the problem is and how I could fix it. Thank you.
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
  • 15 Answers
SOURCE: TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Posted on Oct 17, 2009
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: my york pacer 2750 will not change speed, speed
Unplug unit pull your motor shroud off then inspect the motor pulley assembly plug in your unit while you rotate your speed handle you should be able to see the mechanical adjusting working if not then that mechanism needs repairing
Posted on Apr 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: need a running belt for a York Pacer 3100
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Posted on Apr 24, 2010
Lower speed to 6 klms
I got the manual for another model York Pacer 3501.
See page 5 of the manual
York Pacer 3501 User Manual Page 7
Jun 02, 2016 | York Exercise & Fitness
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
York Pacer 2750 going too fast
Lower board is in short circuit. Reason could be the walking belt creating to much friction with the deck.
Need to contact the manufacturer for electronic, and do not use the same quality belt, you can get a better quality in www.walkingbelts.com.
Sep 19, 2014 | Exercise & Fitness
I cannot adjust th speed on my york pacer 3100, it just goes very fast.
I'd suspect you need a new adjustment cable and/or the winder is broken. The latter happened to my York 2500 Pacer and I replaced the cable & handle with a bike gear change mechanism.
Mar 18, 2014 | York Exercise & Fitness
Treadmill issue: Have a York fitness pacer 3700 that does not go and an error 1 comes on after 4 seconds, prior to this it starts up normally and the display is zeroed. Any ideas?
Adjust the speed sensor, clean, and tight the wire connector very well.
see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
sincerely. God bless you
Apr 19, 2012 | York Exercise & Fitness
Cannot change speed up on york pacer 27650
1) Check it the speed sensor.
2) Watch if the connector is loose or bad contact.
3) Corroded contact( clean with special spray for contact)
4) Replace Speed Sensor.
May 24, 2011 | York Barbell Home Use Fold-Up Treadmill
My york pacer 2750 will not change speed, speed adjust knob work but motor will not increase speed.
Apr 16, 2010 | York Exercise & Fitness
My york treadmill pacer 3700 show error
I have just got a pacer 3700 off a friend and she had no manual for it. it keeps saying error 1 and wont do anything. what can i do to make it run again?
Oct 27, 2009 | York Exercise & Fitness
Speed problem
There is a rotating handle to the right of the display panel that you need to turn clockwise to slow down and anitclockwise to speed up, this is the only speed control. Turn it all the way and it will start at the slowest speed about 4kph. Good luck
Jan 24, 2009 | York Yankees Bedding MLB Comforter
Exercise & Fitness Logo
584 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
