Question about GE Refrigerators
GE MODEL GSL25JFPD BS SOUNDS LIKE A MOTOR IS OSCILLATING, CONSTANT
FAINT SOUND UP AND DOWN. SOUNDS LIKE ITS COMING FROM FREEZER SIDE NOT SURE
  • 61 Answers
SOURCE: GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Posted on Oct 20, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
Posted on May 20, 2009
espressonist
  • 1711 Answers
SOURCE: GE GSL25IFRF BS freezer side fan
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Posted on Sep 15, 2010
  • 1796 Answers
SOURCE: I have a Side by
Hi!!
Just to isolate the problem, try turning off the Ice Maker for a couple of hours. If the whistle continues, it is going to be the evaporator fan motor in the freezer compartment. Check the temp. settings, if the freezer and fridge temp are not balanced, this type of events can occur. Consult your Refrigerator Care and Use Manual for proper temp. settings. If you don't have a manual, click on the following link to obtain one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60458.PDF
Good Luck!! Don't forget to rate this post!! Thank you for using FixYa!!
Posted on Oct 08, 2010
aasc
  • 1606 Answers
SOURCE: GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Posted on Aug 16, 2012
I have a GE gsl25jfta bs side by side, the freezer melts ice box then freezes it again.. Making a block of ice
Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
Jun 18, 2014 | Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Mar 15, 2010 | GE Refrigerators
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Apr 17, 2008 | Refrigerators
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Freezer
I have a GSL25JFPH BS refrigerator by GE. It made the whirring sound, a repairman came out and told me that the fan motor needed replacing, price of $277. I sent him away, and after a few minutes on the internet, saw on this site that a new circuitboard (part# WR55X10656) should fix it. I found it on ebay for $83, and it took about fifteen minutes to install. No more whirring!!
Oct 31, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
