Question about GE Dryers
Lint trap doesn't sit right in dryer. It sticks up and clothes ge caught on edges., ripping clothes
  • 36 Answers
Take the lint trap out, and look inside the slot where it goes. You will see a lot of built up lint which will have to be removed so you can slide the trap back down to the bottom.
Posted on May 05, 2017
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
I have th lg dlgx3002w dryer. the garments get hung up in the lint filter and tears the garment. the edge of the filter is slightly melted. what causes this and how can i keep this from happening again?
I had the same problem. My LG dryer lint trap did the same thing and I ordered another one for replacement. The new lint trap is not rounded on the batton on the corner below where it got bent up and snagged your clothes. The new one is cut at a slight 45 degree angle. I believe that LG changed the design a little so clothes won't get hung up on that edge. Go to this site and you will see a picture of the replacement part. http://www.appliancepartspros.com/lg-dryer-lint-filter-adq56656401-ap4457244.html
Feb 06, 2011 | LG DLE5977 Electric Dryer
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Clothing getting caught on lint trap tab. And clothing getting caught between drum and front of dryer
Probably has extra space between drum because the front felt guides on the drum have worn. This can be accessed by removing the front panel.
Oct 05, 2010 | Frigidaire Electric Dryer
GE profile dpse810gg gas dryer - more lint coming out og dryer vent than caught in lint trap
ck the felt seals on the lint trap and see if its making good seal or if they are missing
Jan 26, 2010 | GE Dryers
Clothing gets caught on lint trap
If your dryer is new, it will have warranty a on it. Request a home visit from an authorized technician at no charge to diagnose/document your issue.
Due to fabric damage, once the cause is determined and corrected, contact the manufacturer for a possible compensation for the damaged items. Take pictures and provide receipts.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Frigidaire GLGQ2152ES Gas Dryer
My GE gas dryer is gets warm but the clothes take hours to dry
Hello there, this could be quite a few things.
The most likely cause is something as simple as a clogged lint trap. I will assume that you have checked this out, but just in case check it one more time and use a flashlight to see if you can spot any lint trapped down a the bottom, below where the lint trap sits.
Secondly, during the summer if you live anywhere where it's humid it will be much much harder for your dryer to do it's job. I was perplexed by this same problem when we moved out here to Minnesota. I thought my dryer was broken for sure, the clothes were warm, the dryer was warm, but the clothes took literally a full day to dry, many many cycles. Is there a chance that this is what you are experiencing?
Lastly, and the most complicated of the bunch, could be a shorted element. If that's the case you could replace it yourself if you are comfortable taking apart the dryer. If it's a newer GE dryer though it's probably still under warranty and they will take care of it for you. I would check with GE in regards to the warranty status. Their phone number is 1-800-626-2005
If none of these things work, please reply (if you can reply within the next 20 minutes or so it will assure that I am the one who continues with the question) and in your reply please include the actual model number of the dryer if you could.
Jul 08, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Our dryer lint trap won't go down all the way and is catching our clothes -- ruining spaghettis straps, bras, etc., twisting everything and catching our clothes on the corner of the trap.
It may be backwards. But the first thing I would look for is if there is lint caught in the shute keeping it from going down all the way. If it is a newer model there is a lint screen sensor that may have come unattached and keeping the lint screen from going down all the way. Good luck.
Apr 19, 2009 | Dryers
Clothes are getting caught on edges of drum
you need to replace the felt on the dryer
Dec 19, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
