Question about Kenwood GPS
Kenwood sd card updates for gps - Kenwood GPS
SOURCE: my gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
Posted on Sep 23, 2007
SOURCE: Hi i have a GPS
http://www.66.com/support/index.php?cid=UK
Posted on Feb 10, 2009
  • 4090 Answers
SOURCE: Navigon 5100 SD Card problem
I woulod think the data is corrupted or not in ther format the GPS is expecting. redownload the data to the PC desktop and see how it is organised
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: how do i update my nextar gps, can't find my model
You have to plug in the GPS to your computer and if there is an update file from www.nextar.com's support area, then you run the executable file and will update the firmware on the unit. There are no new maps. If you can't find your model on Nextar's site, you'll have to contact them - but normally, no model number listed means no new updates. Nextar's support is pretty flaky right now. They're not as big a company as TomTom or Magellan. And they do not make their own maps - they get them from another company called Navteq.
Posted on Oct 04, 2009
SOURCE: Magellan Corp says that the update is simply
My Magellan 1412 has a black piece of tape on the bottom. The SD card is behind this tape.
Posted on Jan 10, 2010
Kenwood Garmin GPS map update
Any advice card below 32 gig should work. Sdxc will not work. I have a 16 gig UHC1 in mine. Works great.
Nov 16, 2016 | Garmin GPS
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
How do I download updates to my gps
http://www.insigniaproducts.com/products/car-audio-video-gps/NS-NAV01.html
Form the manuafacurers web site - The manufacturer is working on a map update however it is stored on the SD memory card in your GPS unit so you may need to contact insignia to find out how the SD memory card is updated and when the update will be released.
I would at a guess think that a memory card reader device may need to used on your P.C and that a download into the sd memory card would be how insignia would achieve an update. But backup what is on the memory card first onto your hard drive in your P.C. before altering its contents if this is how it is achieved.
Oct 20, 2014 | Insignia NSNAV01 GPS Receiver
Kenwood kna-g610 map upgrade problems
Which Garmin update did you use?
The correct update is Garmin Part Number: 010-10679-13.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 08, 2012 | Kenwood Kna-g610 Car GPS Receiver
My gsp only has a sd card no usb slot so how do i transfer the update to my gps Thanks
Depending on the type of GPS you have, you have a few options...
If the update instructs you to put the update files on the SD card, you need a means for your computer to access the SD card. This can be done by using an USB SD card reader, which can be picked up at your local electronics, digital photography store or online.
If you have another device that allows the transfer of data between a computer and the device (and it uses SD cards), you can put the SD card for you GPS into your other device, connect it to the computer through USB, and transfer the update files. For example, if your digital camera uses an SD card, you could put the GPS SD card into the camera, and then connect the camera to the computer.
Make sure you're updating correctly - sometimes the update is a file you run on your PC that in turn transfers files through a different means onto the GPS. Read the manual for your GPS for more information regarding transferring files onto the GPS and updating.
Mar 12, 2011 | GPS
Change gps software
GPS software is compiled, specific to the brand, so any other maps you try will possibly not work
Jul 04, 2009 | Kenwood DNX7120 Car GPS Receiver
Won't read an SD card
It sounds like either your GPS plug came out of the back of the unit, or your gps does not have a clear view of the sky, or if the gps is mounted on a trunk that opens and closes a lot the wire can break inside. I dont think the software is your issue, just to make sure if you update make sure the update file is the only file on the card, if there are other files (left over pictures, etc) they can cause the unit to disreguard the whole card.
Jun 30, 2009 | Kenwood DNX7100 Car Video Player
How to install map update adta card
It's on the side of the unit. There's a cover that flips up to reveal the SD slot.
Dec 30, 2008 | Kenwood KNA-G510 GPS Receiver
GARMIN 510 2009 MAPS
I'm quite sure you need to purchase the 2009 City Navigator SD card to update the maps. That what I did last year to get the 2008 City Navigator maps. You will need to leave the SD card in the unit to use the new maps though..
I haven't been able to determine whether it's possible to update the actual install map on the device. I'm guessing it's possible but would require a computer and an map update to write directly to the device. If I find steps to update the installed maps, I will post them here.
Oct 08, 2008 | Kenwood KNA-G510 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
51 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
