I need to get Petrece Motsepe to be my key note speaker at a network evening for smme's
Patrice motsepe email address
hi Jeffrey.
this is what i have found.
Motsepe Foundation
or this one.
Contact Us Motsepe Foundation
Patrice motsepe email address Google Search
see if any of the above helps you out.
Nov 22, 2017 | Computers & Internet
I had a Nokia 6555b ,but I forgot pass code,and now I need your help to find hard reset for it.
Oct 26, 2013 | Cell Phones
Need network security key
It depends. Not kidding!
Depending upon the available hardware and access to the wireless router, it could be as simple as examining the outside of the router and reading the network key off of a label on the router. failing that, you would likely need to have an ethernet cable that you can use to connect directly to a port on the router. Note that not many routers will allow access to the configuration through the wireless connection. You might be able to get to the smart part of the router by then using your browser. You can usually find the router manual on the internet to get the default IP and admin password to access the configuration. If nobody changed the configuration, then just getting access to the configuration should display the wireless key.
If this router is on your own network and you've forgotten the password, and you want to add some equipment, then consider resetting the router to factory settings, and default SSID and key. Check your manual, but usually putting a toothpick into the tiny hole and holding it for a number of seconds will cause the router to reset.
Once the router resets, you can access the configuration and set your password and SSID to what you want. You'll then need to configure all your other equipment with the network name and key.
Even if you have a PC that does talk on the network with the router now, you probably won't get the PC to show you the key for the network in the clear.
Dec 25, 2011 | Belkin Computers & Internet
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
My Vizio HDtv WIFI shows a good signal from my Linskys router but is "unabke to connect" even though I repeatedly enter the correct pass phrase, what is wrong?
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen. If you don't see the Wireless Network Monitor icon, click here.
kb_4285-001_en.png Step 2:
Click the Site Survey tab and select the name of your wireless network or SSID, then click Connect. In this example, we used a wireless USB adapter.
NOTE: images may differ depending on the model number of the adapter.
Step 3:
If the software is asking for a WEP key, enter the WEP key on the WEP Key 1 field.
If the software is asking for a WPA-Personal key, enter the WPA key on the Passphrase field
Nov 02, 2010 | Computers & Internet
FORGOT MY WEP CODE
I WILL NEED TO KNOW YOUR ROUTER'S MODEL/MAKE!
First, go to your router's ip address (depends on each router)Then, login to your router (default username: admin default pass: blank or admin)
There, under tools or network security or similar to that sort, look for your network/WEP key. There, you should be able to find your network key to access the router's network, and even change it if needed.'
Hope this helps, please rate ^_^
BE SURE TO TELL ME WHAT ROUTER YOU HAVE THROUGH COMMMENT! THANK YOU ^_^
Jun 19, 2009 | Actiontec GT704WG Wireless Router...
Limited or no Connectivity WG111v2 SBG900
Limited or No Connectivity on Windows XP
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Feb 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wep key entering
network key is very case sensitive no spaces should be there even if there are spaces or a dash when you see it in the router page but when you are entering it in the laptop it should be continous,and make sure you make a note whether the alphabets are in upper or lower case..since it is case sensitive it need to be entered exactly the way it is setup in the router..
vedhick
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
