Question about Bissell Vacuums
This sounds silly I know....however, I just bought a bissell revolution x2 pet pro carpet cleaner and the handle is supposed to easily snap into base and should hear a click...i can't get it to
SOURCE: I have a Bissell pro heat carpet cleaner, the
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
Vac Belts
  • 701 Answers
SOURCE: where can i obtain a manual for a power steamer
You can view the manual here:
Bissell Powersteamer Manual
Posted on Dec 02, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
How to replace belt on a bissell 66e1 pro heat lift off pet carpet cleaner
There are two belts on your model. Remove the screws on the end cap assembly on each side to remove the assembly to gain access to the belts. Remove the screws holding the brush roll assembly to remove and replace the belts.
Jan 08, 2017 | Bissell Vacuums
How do i fix my Bissell pro heat turbo x2 carpet cleaner it wont suck up anything?
Check the vacuum hose and head for link clogs from carpet fibers
Oct 30, 2016 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Pet hair stuck in plastic top of tough stain brush tool
On some of those, the clear cover snaps off. If it wont, then use a pipe cleaner to reach those spots after you let it soak for a while in warm soapy water.
Nov 26, 2015 | Bissell 1400-7 Little Green Clean Machine...
My bissell pro heat pet carpet cleaner wont suction
I have a pro hear Boswell I can't.get it to sick up water help
Apr 03, 2014 | Bissell Vacuums
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
My Bissell ProHeat Pet Carpet Cleaner will not spray water. Can you help me troubleshoot this problem?
I have cleaned the heater but still having the problem so what can I do
Feb 26, 2012 | Bissell Vacuums
Replacing the little black rubber belt
bissell.com has videos on how to replace belts.
May 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
