Question about Hotpoint Washing Machines
A Hotpoint washer model WT540 cuts out halfway through a cycle and the pre-wash light flashes. Any ideas?
4 Suggested Answers
  • 278 Answers
SOURCE: rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Posted on Oct 15, 2009
SOURCE: WDL 540P Hotpoint Wash Dry:Where is the Prechamber located ??
tung
Posted on Mar 06, 2010
  • 6277 Answers
SOURCE: my hotpoint aquarius WT540 washing
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 06, 2011
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Flashing pre-wash approx 1 hour into wash cycle instead of moving onto rinse and wash. Whats causing this? This is happening on the WMA50.
Hi! If the pre-wash light flashes it means you are not getting enough water in the machine, check the pressure chamber, pressure switch, fill hoses and valves. For a workshop manual on the WMA50 which includes fault finding, visit www.selfix-uk.co.uk
Feb 17, 2011 | Hotpoint WMA50 Front Load Washer
My washing machine wont start up all flashing lights on LED's Basically i click on the start button and all the LED's start flashing continuously. Initially it flashed for about 3 minutes and then i could...
Machine is finding a problem during the initial diagnostucs on startup. Check for damp, condensation on the carbon brushes or worn brushes. Also check for earth leakage.
Dec 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Oct 15, 2009 | Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
I have a Hotpoint Aquarius WT540 and it will need complete its wash cycle and will not got the spin cycle. Two lights are flashing. I have took the bottom panel off to check the filter. I undid the...
just give it a tug. possibly tight because something caught in it - bra wire or similiar.
you may have a lot of water out so have towels handy and make sure it doesn't go on the motor
Jun 25, 2008 | Hotpoint Washing Machines
Hotpoint WT540 problem
You have to check your pump, probably clogged
May 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
