Question about Furniture
I have a Koolatron WC168DZ wine cooler that runs with R600 A, it will not cool and I hear a clicking sound, it has been diagnosed with a locked rotor any help on how to fix?
fridgetech
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
Good day ! I have a Koolatron WC12 cooler that stopped cooling ,the fan works !It is not even a year old ?
1-800-265-8456 phone # for parts/service
Koolatron
U.S.A.
433 0 Commerce Dr.
Bata via, NY 14020-4102 U.S.A.
It is out of warranty if more than a year old.
I can find no service manual. There is a generic video: http://www.newair.com/kb/repair-cooling-kit-wine-cooler/
Replacement parts were sold at Truck Stops. That said, coolers are not known for their longevity. Source: http://www.truck-drivers-money-saving-tips.com/thermoelectric-cooler.html
What to Do When your Wine Cooler Wont Cool
Jun 10, 2017 | Koolatron Refrigerators
My Koolatron Wine Cooler, model WC08 will not turn on. Any ideas what I should check first? I checked the outlet. It is fine.
There has to be an internal breaker that went off or fuse. You may have to remove it from the casing to get to it.
Jun 26, 2016 | Koolatron WC08 8-Bottle Countertop Wine...
There is hoarfrost in the top of the upper level and water at the bottom. What can we do? Is it better to turn off the appliance and let it de-ice? Did you hear about this problem before? Thank yo
I have had a similar problem with a commercial fridge that uses a fan to move the cold air around. The cooling elements get frozen and so no cold air is distributed by the fan.
It seems to happen when there is a weather change, maybe something to do with humidity?
Try turning it off for a day (put towels down) and then it should be fine.
Nov 15, 2014 | Koolatron 45 Bottle Dual Zone Wine Cellar...
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
My wine cellar doesn't cool
Since november2014 I'd tried having my koolatron 18 bottles cellar repair . no parts aviable no koolatron assistance and when i'd phone no answer. that' s SCRAP ...
May 12, 2014 | Koolatron 18 Bottle Dual Zone Wine Cooler
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
I have a Haier Model BD00T0E0200 that is getting power, the compressor is warm to the touch, is clicking occasionally, but does not cool. Any suggestions?
Hi and welcome to Fixya. I am Kelly
First of all unplug the unit for at least 30 minutes and let the compressor cool off. That clicking your hearing is the "KliXon" thermal overload trying to protect the compressor because it is not starting.
Failure of a compressor to start can be caused by several things.
1. A bad PTC Relay / KliXon mounted on the compressor
2. A bad run capacitor
3 The bad news... a LOCKED rotor in the compressor.
There is one other possibility and that is that the power cord plug is not making good contact with the wall outlet terminals. (very rare that this happens)
Just make sure to unplug the unit for at least 30 minutes. Use a fan for cooling the compressor if you can by just pointing it toward rhe area of the compressor. After 30 minutes plug the unit back in and cross your fingers...... If it starts your in luck... If not then your going to need to service the unit.
Again thanks for using Fixya and if you need further assistance just reply here. We get notified of all responses. Kelly
Feb 07, 2010 | Haier BC112G Wine Cooler
Clicking sound and not cooling
compressor grounded. replace relay or compressor
Jan 02, 2010 | Haier HVFM20ABB Wine Cooler
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Furniture Logo
170 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
