Question about Mercury Boating
I have a 1999 mercury mariner 5hp 4st motor, there's gas coming out of 2 holes in the top of the carburetor
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 83 Answers
Sounds like pressure builds up. I would say to rebuild the carb. Very easy job to do.
Posted on May 07, 2017
How to drain carb bowls on 1999 mercury 2strock 3cyl 60hp outboard
Hey Geoff,,, there is a "bolt" on the side of the float bowl,, unscrew and remove it,, gas should flow out, freely.,,while the "bolt" is out.. pump the bulb and this will help flush out some crud..BUT - For a complete cleaning,.. you need a qualified professional... its #25 on the diagram Parts for Mercury Marine 60 HP Bigfoot 3 Cylinder Carburetor
Jul 04, 2017 | Mercury Boating
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
Whats the firing order on a mercury 500 thunderbolt marine engine ?
Remove the 4 spark plugs , number 1 is the top piston so put it to tdc then with a screw driver feel through each plug hole for which is the next piston to come up to tdc etc etc till you have written the order ! 1,2,4,3 or 1,3,4,2 !!
Oct 14, 2014 | Clymer Mercury/mariner 75-275 Hp...
5HP Mariner outboard no water coming out of water outlet, a water system diagram required
It would be nice to have a year.....but you dont need a diagram. in back of the prop on the lower unit there should be 3 or more holes/ slots on each side.....water gets sucked up from here. then where your lower unit bolts on to the tower there is a waterpump on the inside it pushes water through a 1/2 metal tube into the bottom of the motor then it squrits out . if its not sucking up water and or peeing then you have 1 of 2 problems
#1 blockage in the peeing tube. bugs and mud dobbers like it in there. gentle push a clothes hanger into the tube.
#2 bad water pump I change mine every year call me crazy if you like but if you run your motor without water you will be buying a new one
Apr 22, 2014 | Boating
Mariner outboard 5hp overheating
clean the lower unit intake holes and
PUT IN A NEW WATER PUMP IMPELLER!!
Jun 20, 2013 | Mercury Boating
I have a 5hp B.& S. horizontal crankshaft engine that has started to flood badly. I suspect that the needle valve is stuck open but I don't see it. The carb. is mounted on top of the gas tank. How...
On models with the carburetor mounted on top of and part of the fuel tank do not have a float and needle valve. make sure the air cleaner bolt/screw is all the way in or else the engine will **** fuel through the threaded hole for it. If this is a different kind of carburetor let me know.
Jun 07, 2010 | Garden
Mariner outboard motor starts runs, then fuel comes out overflow and motor dies.
If you have carburetors your float is stuck. It can happen more than it should and if it is a smaller engine, laying it on its side can cause it.
You would have to look at the float and imagine which way to lay the engine down in the future. The float could also be bad. You would take it out and float it in Gas, not water to see if it sinks.
If this is a big HP outboard and injected your fuel regulator is bad.
Apr 06, 2010 | 2000 Mercury Mariner
How to clean boat carburetor. 1984 35 hp mercury outboard sprays gas out of small hole towards top side of carburetor when starting. Motor will start on occassion for 5-10 seconds, but then gas will spray...
Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
Feb 14, 2010 | Light Outboard Motor Boat Bass Fishing...
1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Jun 07, 2009 | Boating
Boating Logo
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Joseph Hoffmann
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
