Question about Siemens Washing Machines
Siemens EXTRA 1550 front load washer water level too low
My Siemens EXTRA 1550 front loader washer doesnot fill up with enough water to thoroughly wash and rinse the clothes. Isthere a way to adjust the automatic water level sensor on the machine?
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
landsend
  • 1066 Answers
SOURCE: agitator seems to bind up when in wash and rinse cycle
you need a new coupling between the motor and the transmission.
Posted on Mar 08, 2009
MNTECH
  • 1543 Answers
SOURCE: Can you adjust the water level on the LG Tromm WM1814CW?
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Posted on Apr 07, 2009
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Is it getting enough water?
For front loaders, they usually have the level underneath the door, they use small amounts of water, but they spin so all the clothes do get
soaked with water.
Feb 05, 2010 | Samsung WF317AAG Front Load Washer / Dryer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer doesn't get enough water in it to wash properally.There isn't a water level knob on the washer.Its a frontloading whirlpool.
There is most likely nothing wrong with the washer. Front load washers will only fill about 2 inches of water in the tub. As the load starts to tumble, water is absorbed into the clothes, causing the water level to drop. The machine senses this and adds more water. The process continues until the water level stabilizes. (thus no need for a water level switch) Your clothes should get wet, but you will little if any water. If you use a gentle cycle you will get slightly more water, as the washers tumble at the same speed for all cycles, but give a more gentile wash if there is more water in the drum.
Also,..... remember because you have so little water in a front load washer (compared to most all top loader models) you want to use only 1 to 2 (max) tablespoons of HE detergent per load!
Aug 27, 2008 | Washing Machines
Water levels
Probably the nivauchamber is clogged of lime or something. Or you are overloading the machine
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
