Question about Troy Garden
My Troy built starts runs for a while then shuts down...can u help me
  • 72 Answers
SOURCE: Lawn mower starts up , but only runs for 5 seconds
dirty carborator. needs to be removed and cleaned there is dirt in the main jets
Posted on Aug 04, 2009
SOURCE: troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Posted on Sep 11, 2009
MOTORWIZJ
  • 1338 Answers
SOURCE: my troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My Troy built self propelled mower with HOnda
Most of the time this is caused by the low oil level sensor on the engine. First check the engine oil level in the engine and make sure it is full. If it is at normal levels then to check if it is infact the oil level sensor that is causing the problem disconnect ONE wire lead from the oil level sensor. If it runs normally after disconnecting the lead either the oil level sensor is very dirty or has failed. Should this not be the probelm just respond here and I will get back to you usually the same day. If you know your engine model number (on crank case not far from the base of the oil fill) please include that with any responses.
Thanks for choosing Fixya.
Kelly
Posted on Jul 05, 2010
SOURCE: My troy built 2200 pressure
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Posted on Oct 12, 2010
Zero turn mower shuts doun when trying to go when engaging control arms
On my RZT50 Troy Built I have to engage the parking brake to start it and release it before I move the arms in over my lap or it shuts down.
Dec 10, 2016 | Garden
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Why does my Troy built pressure washer have no pressure and shuts down
There is probably a bypass valve in the pump not working correctly causing pressure to build up inside the pump, not releasing , and putting the motor under strain until it dies.
Jul 06, 2014 | Troy-Bilt Garden
I have a troy built chipper schredder vac built by garden way in 1992 that has a tecumseh engine model h50-65578t that i would like the carb adjustments .
start at one and a half turns each ,run at full throttle turn outhigh speed screw (bottom) until it starts running flat, turn back untill runs clean. same procedure for low speed screw but at idle speed .when done turn throttle to high speed if boggs open low speed screw alittle bit at a time untill accelerates with out bogging hope this helps
Aug 09, 2010 | Troy Bilt Builtchipper...
My troy-built blower will not start
May 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy Built Ride-on, stalls when blade is engaged.
You may have a short in one of your safety switches. There is usually one on the seat that shuts it off if you try to get up and one on reverse if you try to back it up. I would look there to see if somehow they are grounding out
If you can get it where you can grab the blades, check and see if they float easy. You could have a seized bearing on one of your blades that is stalling out the motor as well.
Hope this helps
Aug 20, 2009 | Garden
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Troy built lawn tractor won't start.changed plugs.
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
26 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
