Question about Frigidaire Washing Machines
I have a Frigidaire stacked washer and dryer model # fex831fso. The back legs do not screw up and down like the front legs one is standing out and the other is all the way in and neither one will move
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
the dr
  • 447 Answers
SOURCE: Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Posted on Nov 24, 2007
SOURCE: How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Posted on Jun 26, 2008
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
  • 4 Answers
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
Fex831fso squeeky drier
Good Morning Friend,
I understand that the dryer is squeaky on your Frigidaire laundry center, model# FEX831FS0. There could be numerous possibilities causing the squeaking sound in your appliance. I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine what is causing the squeaking sound. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire FEX831CS Top Load Stacked...
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
It continues to take water, it drains itself, doesn't start the washing cycle MODEL FEX831FSO SERIAL XE70303963
Hello, Thank You for using FixYa. I will be helping you today. Check the drain line make sure its not too far into the drain or too low or it will continue to drain and fill.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLEH1642FS washer/dryer stacked unit: How do I disconnect the buzzer?
The buzzers (there are two, one for the washer, one for the dryer) are behind the control panel. 6 screws must be removed to access the back of the control panel: 2 for the service panel, the 2 outer screws at the base of the control panel, then the 2 much smaller-sized screws.
The buzzers, in my model, are small, un-buzzer-like-looking little black boxes stamped with the brand name 'Ark-less'.
The buzzer for the dryer is connected to 2 contacts on the back of the dryer timer, the contacts labeled 'H' and 'C'.
Once you've identified the buzzer for the dryer, you should be able to find the one for the washer. It's connected by one white and one grey wire.
You should be able to verify this info using the wiring diagram, which will be located behind the service panel. If I remember correctly, the buzzers were labeled 'signal' on the diagram.
Nov 07, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
How to open the back of Frigidaire FEX831CS to change belt.
Remove the two screws from the bottom of the FRONT panel. The panel drops down and pulls off. You change the belt from the front
Jul 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
Trying to trouble shoot problem with Frigidare stack top load was
There are 2 screws on the bottom/front of the cover to the washer. Remove the screws. Near the top/front of the cover is a seam; insert something flat in the seam (such as a screw driver blade, covered as to not scratch the finish)and pry the cover downward. This worked for me.
Jan 28, 2009 | Frigidaire GLET1031 Top Load Stacked...
Stacking dryer
the 2 plastic pieces 1 goes on front 1 on back,,place the one that has open for dryer legs on back,,,and the one in front does not have openings you must pick up dryer to get font on ,,slide back first than pick up front
Dec 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Stacking the washer and dryer
Been a while since I did one, but as I recall: Two side pieces secure to top of washer with peel off tape and a screw into the top at the very back of the washer's top. Dryer sets on top of washer with back legs sliding into the stack kit side parts. Front rail holds front dryer legs, secured by one screw on each side into stack kit side pieces after dryer is set on top of washer.
Nov 09, 2008 | LG WM-2277HW Front Load Washer
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Directions on stacking dryer on washer
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
