Simplify. Write your answer using whole numbers and variables. 9j2+4j// 9j+4
5 Suggested Answers
  • 8073 Answers
SOURCE: After doing this division
The TI84 has two commands fPart( and int(. They are accesible by the sequence
[MATH][NUM][4] fPart(
[MATH][NUM][5] int(
Once you select the command it shows on home screen> you complete the command and press [ENTER]
Let the number be 15.78
int(15.78) [Sto->] [ALPHA] [F] stores the inter part of the number (15) in variable F. Similarly
fPart(15.78) [STO->] [ALPHA] [I] stores 0.78 in variable I.
Hope it helps
Posted on Sep 05, 2009
  • 8073 Answers
SOURCE: Variables
This calculator cannot handle symbolic algebra.
Use the rules to simplify the expressions: Get rid of the parentheses using distributivity od multiplication with respect to addition; group similar terms (terms with x, terms without x).
Hope it helps.
Posted on Sep 27, 2009
  • 60 Answers
SOURCE: Argument error whenever I type equations with variables.
Perhaps you have some data stored in the x variable.
With the calculator on, press [2nd] then the minus button. This brings up a list of all the saved data in the calculator. Look through the far left column of the list for x.
If you find x in the list, highlight x, then press F1, and then select delete.
Now it should work like normal.
Posted on Nov 07, 2009
laughton5983
  • 2192 Answers
SOURCE: How to simplify 5/2 into a whole number
Divide the upper by the lower to get the answer
Posted on Nov 04, 2016
Nov 04, 2016 | Office Equipment & Supplies
Simplify the expression 0.2y3+0.3y3+0.1y3 use integers or decimals for any numbers in the expression.
All the terms in the expression have a common variable factor (y^3). factor it out to get (0.2+0.3+0.1)y^3=0.6y^3 or (6/10)y^3 or (3/5)y^3.
Apr 19, 2013 | Office Equipment & Supplies
Simplify a ratio
Divide both sides by their greatest common factor.
Mar 14, 2013 | Fein Wpo 12-27 E 10-in Variable Speed...
Give some example of math equation?
The following are examples of expressions:
x
3 + 7
2 × y + 5
2 + 6 × (4 - 2)
z + 3 × (8 - z)
Example:
Roland weighs 70 kilograms, and Mark weighs k kilograms. Write an expression for their combined weight. The combined weight in kilograms of these two people is the sum of their weights, which is 70 + k.
Example:
A car travels down the freeway at 55 kilometers per hour. Write an expression for the distance the car will have traveled after h hours. Distance equals rate times time, so the distance traveled is equal to 55 × h..
Example:
There are 2000 liters of water in a swimming pool. Water is filling the pool at the rate of 100 liters per minute. Write an expression for the amount of water, in liters, in the swimming pool after m minutes. The amount of water added to the pool after m minutes will be 100 liters per minute times m, or 100 × m. Since we started with 2000 liters of water in the pool, we add this to the amount of water added to the pool to get the expression 100 × m + 2000.
To evaluate an expression at some number means we replace a variable in an expression with the number, and simplify the expression.
Example:
Evaluate the expression 4 × z + 12 when z = 15.
We replace each occurrence of z with the number 15, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
4 × z + 12 becomes
4 × 15 + 12 =
60 + 12 =
72
Example:
Evaluate the expression (1 + z) × 2 + 12 ÷ 3 - z when z = 4.
We replace each occurrence of z with the number 4, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
(1 + z) × 2 + 12 ÷ 3 - z becomes
(1 + 4) × 2 + 12 ÷ 3 - 4 =
5 × 2 + 12 ÷ 3 - 4 =
10 + 4 - 4 =
10.
hope that help you
Jun 22, 2011 | LeapFrog Turbo Twist Math Cartridge 5th...
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
Find the value of the variable ''x'' 6x+6=4x+12
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides.
6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x.
2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides.
2x=-6+12
Add 12 to -6 to get 6.
2x=6
Divide each term in the equation by 2.
(2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors.
x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term.
x=3
Good Luck
Sep 10, 2009 | Audio Players & Recorders
After doing this division "7/4" I get the answer "1.75". I want to keep the whole number in one variable and the decimal part in another variable. What kind of program I could use to do that? Million of...
You may be able to find a program online that will automatically do what you want however if you don't have to do this too often you can just manually set "1" to a variable via the "STO-->" button (right above the "on" button-- select the value, pres sto-->, alpha and whatever variable you want) and set the ".75" to a variable.
Finding a program may be difficult for this type of program because you're trying to separate a whole number (essentially looking for a whole number and the remainder). You could always write a program for yourself but as I said before it might be a bit difficult.
Jun 25, 2009 | Texas Instruments TI-84 Plus Calculator
Variables
Hope it helps.
May 07, 2008 | Casio FX-115ES Scientific Calculator
21 people viewed this question
k24674
jasbo
jasbo
