Question about Sharp Televison & Video
I have a sharp smart TVs but can't get in to Intel wireless display lc/43cff5111k led colour what do I have to do please
  • 1894 Answers
SOURCE: Sharp Aquos LC-30hv4u
this looks like a power problem sir.
do you use a surge protector?
Posted on Jul 14, 2008
gripfitter
  • 557 Answers
SOURCE: We have a Sharp LC-42PD7X LCD Colour TV and the
Go into the menu and rescan. You want digital and analog or channels ALL.
Posted on Sep 27, 2009
SOURCE: I bought the Sharp TV LC-32D43U in 2007. Now it
Well for a start, they are NOT all the same models, also. a certain percentage, are expected to, and do fail. You see for a good repair, you need to contact, a local Sharpe, office, and ask, for a referral, to an Authorised Service Center, repairer. It is indeed worthwhile contacting Sharpe, as often, a service bulletin, has been issued, that maybe to do with your set, and if your set was in the repair bulletin, then you may even get your set fixed for free, or at the least very subsidized. So you see until, you contact, an Authorised Service Canter, and inquire, always ask for a "Quote" this way, you can find out what's wrong and how much, you can expect to pay.
Posted on Apr 24, 2010
ItsDeadJim
  • 78 Answers
SOURCE: Is there supposed to be a vga driver for XP with this tv?
Also most if not all graphics cards of the last year or so (2009 to present) will either have directly and HDM, composite or SVIDEO output.
You might get better results using these rather then the VGA output.
Posted on Feb 03, 2011
  • 15 Answers
SOURCE: LC-42DH77E Sharp No picture Green led comes on
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Posted on Apr 30, 2011
SHARP TV MODEL LC-46LE830U WILL NOT TURN ON. I HAVE REPLACED THE POWER SUPPLY BOARD WITH NO HELP. IT HAS 2 BLINKING LED LIGHTS FOLLOWED BY 5 BLINKING AND REPEATING AGAIN. WHAT IS MY NEXT STEP?
It sounds that the main board fitted with your Sharp television is of Philips. Those blinks are fault indications, and you should follow the procedure of counting the number of blinks, as you do with Philips brand LCD TVs.
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Sharp Televison & Video
Sharp LC-70LE650U blinking code 2 slow 5 fast
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Some models of Sharp TV uses Philips main board. If your TV has such a board fitted, you should follow the blink count procedure for Philips. From your description itself, I do understand that your TV is fitted with such a board. The blinking code procedure seems so.
Nov 05, 2016 | Sharp AQUOS LC-70LE650U 70" LED TV...
Somehow getting access to the actual internet on my aquos sharp TVLC
The TV will connect to your wireless router but not other devices in your network. You can connect to a HDMI port with a cable to your PC and select that port on the TV.
Jul 27, 2016 | Sharp " AQUOS - 70"" Class - LED - 1080p -...
Sharp LC70le650u dead set, error code, 2 sloww flashes 5 fast. I have done a reset twice
Jun 07, 2016 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
1 short 1 long blink on sharp aquos LC-60LE820UN
Blinking codes details of many popular brand TVs are given. Surf the site with patience. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 24, 2016 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
I have a Sharp LC 52LE640U TV. It has a 1 Blink Fast and 1 blink SHort. I can Power Tv on with CH down/ Vol Up upon power up and it will show display. Only problem is; half the backlight on left si
Some models Sharp TVs uses Philips kit. If yours is such, the blink count procedure is entirely different. It is not direct.
Jan 11, 2016 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
HOW DO I CONNECT WIRELESS KEY BOARD TO MY TV. SHARP MODEL LC-60LE650U
Does tv have usb input? Usually usb is for mass storage only, as the tv wont know the driver for a keyboard, but you can try.
Sep 02, 2015 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
How do I get please run channel autoscan off the screen
On my older sharp non-smart TV there is a back/return butting on the remote.
Feb 14, 2015 | Sharp LC-60LE600U 60" LCD LED TV 1080P
What's the difference between a hisense smart TVs and a hisense smart led tv
LED Smart TV saves Power and Contrast & Colour you will get better than Smart TV.
Jan 25, 2015 | Hisense Televison & Video
Help, my Sharp LC-70LE640U turned of by itself after only a week of use.
If it is brand new, and under warranty period, it will be best to replace this TV. Check the site linked below. There are some details about these type of faults to Sharp LC series TVs. Blinking codes are also described in detail there. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | Sharp LC-70LE640U Aquos 70" Class 1080p...
Televison & Video Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
