Question about Garden
Have a 240 series wheelhorse model 42-16be01-2000001&up.when mower deck is engaged,it discharges the battery.
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
jyackle5
  • 8197 Answers
SOURCE: i need the belt diagram for a toro groundsmaster
May I also get the serial # so I can get you the right belt diagram.
Posted on Jul 03, 2010
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Everything works fine until I engage the PTO for the mower deck. The battery discharge light comes on and eventually the battery goes dead.
The PTO clutch is an electro magnet. There is probably a dead short within the clutch body. Replace the Clutch.
Aug 26, 2015 | Cub Cadet Garden
Blades will not engage on huskee LT4200
Probably the PTO cable is either coroded up and struck or it is broken. You will need the 13W model number from serial tag to look-up as there is at least 2 different cable for this model series.
Feb 27, 2015 | Huskee Tractor Replacement Riding Lawn...
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
