SOURCE: no sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
SOURCE: need to unlock regional to multiregional
Look here: http://www.dcevolution.net/panasonic/index.php?option=com_content&task=view&id=62&Itemid=95
and here: http://www.gadgetguy.de/2006/12/03/panasonic-sa-ht335-codefree-firmware/
Looks like in order to do it yourself you need a modified ("chipped") remote and the code. But for about $40-$50, you can get a kit from places like: http://www.multiregionupgrades.com/ or on eBay fairly easily.
SOURCE: unlock DVD SA HT930
My husband just unplugged it for 30 secs then plugged it back in and it unlocked.
SOURCE: Panasonic dvd home theatre SA HT690
contact panasonic customer service and tell them the model# of the sub , just tell them you need a replacement , they will ship it out to you at a reasonable charge and sometimes they,ll send them out for free if the unit was just purchased because you can tell them it was,nt with the unit and that always seems to work for , Hope i was able to help and if you think i was helpful please leave a nice rating Thank you sincerely glenn mayer
SOURCE: I have a panasonic dvd
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
