Question about Refrigerators
I have a really big frozen ham i need to defrost an cut up an refeez is that saFE TO DO
I cut half a 16 pound ham and baked on 12/23/2017 and put remainder wrapper in freezer wrap in refrigerator is it to old to fix today
That depends if it is a salted ham such as gammon then the salt retards very effectively the bacteria growth, if it a plain unsalted ham then look at it if there is discolouration and a smell that is caused by bacteria growth on ham.
use your instinct and if unsure better safe than sorry and bin it.
see this link for food safety info its says 3 to 4 days for fresh (uncured) ham so that would mean its not safe to eat,
if its cured ham eg. salted then 3 to 5 days and still too old
there are many variations of ham so check this chart to decide
https://www.foodsafety.gov/keep/charts/hamstoragechart.html
Dec 30, 2017 | Refrigerators
Had a fully cooked ham and heated it up with the dressings for it. can tjis ham be frozen
hi Verene.
If you have leftovers, you can easily store ham in the refrigerator for up to a week. However, if you have a lot, or even a whole cooked or smoked ham left untouched, youcan keep it in the freezer for longer storage. ... 2 Place your sliced or cut-up ham into airtight freezer bags.
How to Freeze Cooked & Smoked Ham - Living The Bump
living.thebump.com/freeze-cooked-smoked-ham-7911.html
Can you freeze a cooked ham?Experts recommend freezing uncooked, uncured and fresh ham for 6 months or less. If the ham has already been cooked, it should be frozen for 2 months or less. If you plan on freezing a ham for more than a couple of months, you should buy it uncooked, put it in the freezer and then thaw it when you are ready to cook it.Can You Freeze Ham - Dereezedereeze.com/food-and-cooking/can-you-freeze-ham/Search for: Can you freeze a cooked ham?
if you need to read up some more then go to this link.
CAN COOKED ham be frozen Google Search
Nov 25, 2017 | The Kitchen Appliances - Others
I need to know it okay to eat a ham that been in the freeze for a year I got from a job I never open it up I just put in the freeze how long before it not any good to eat
If it has been frozen the entire time it should be safe to eat. Most anything that has been continually frozen should be safe to eat if cooked and eaten soon after thawing it out. Bacteria is what spoils anything and bacteria cannot multiply in a frozen environment. Depending on what it is,how long it was frozen and whether or not it was exposed to air while being frozen will determine whether or not there is an undesirable change to the taste, color or texture.
The best (safest) way to thaw anything out would be slowly in a properly working and set refrigerator.
Your ham should be OK,especially if it was frozen in its original plastic packaging without being opened or exposed to air before freezing. I have eaten previously frozen hams and turkeys (in their original packaging) that were in my freezer a lot longer than one year... and I never noticed any difference in taste.
Nov 14, 2015 | Home
Frozen ham/with bone. How long after defrosting can you use it
http://www.recipetips.com/kitchen-tips/t--743/ham-preparation-guide.asp
Mar 16, 2015 | Home
Refreeze unopened vacuum package cooked ham that has thawed in refrigerator?
It is not best practice to refreeze things and it is the sort of thing that gets people sacked from catering jobs and other food-related employment because in that sort of environment the practice is against hygiene regulations.
We have all done it and mostly got away with it but I wouldn't risk it with a product that will eventually be eaten without further cooking. Refreezing stuff that will be cooked or thoroughly heated after eventual thawing is a calculated risk environmentally and economically-minded people are willing to take but cooked ham is a risk too far unless you intend to use it in soups, hashes or similar.
A heavily smoked ham would probably survive the process in a slightly safer condition than unsmoked.
I hope I have helped you make a good decision.
Mar 01, 2015 | Refrigerators
How long can i freeze leftover ham
The answer is that it depends. I don't recommend freezing ham radios. Your owner's manual probably has specified a safe range of operation. Freezing your radio will more than likely cause permanent damage.
If you are talking about the food ham, you are in the wrong place. You can store ham frozen for as long as you want, provided you don't mind freezer burn. Generally three months is about the longest you can freeze cooked meat and maintain the quality.
Dec 30, 2013 | Radio Communications
I had a power failure and my amcor fridge/freezer, with 3 stars, was off for 17 hours. Is the food still safe to eat(meaning if it defrosted and got re-frozen
If the food defrosted then no its not safe to re-freeze, but if the door was kept close then it should of maintained a frozen state.
Mar 02, 2011 | Amcor Refrigerators
Tried wash after freeze, pump may be frozen
What you need to do is, let it sit a defrost. If you try to many times you will kill the motor and pump. Let sit for 12 hrs. Just to be safe
Jan 11, 2010 | Whirlpool GHW9300 Duet Washer
Defrosting problems
Hi, Can you get me model # so I can assist you further?
Are you getting ice or frost in the freezer?
I can help
Vic
May 27, 2009 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
