Question about Cell Phones
Repair phone glass - Cell Phones
    New Friend:
What phone
Posted on May 05, 2017
Where do I get instructions to repair android 4.1.2 digitizer glass
your android system has nothing to do with the glass.. you need the make and model of the phone to find replacement glass.
Apr 04, 2015 | Android Cell Phones
How do I change broken glass in 7024W?
do you mean a place that will fix it for you or are you planning on DIY repair. If you want to take it somewhere you could contact the manufacturer of the phone.
http://www.alcatelonetouch.com/global-en/support/faq/service.html
if you are planning on DIY it is real easy to damage the digitizer under the glass when trying to replace the glass. You can buy replacement glass but you need to heat up the glass to the point that the glue melts and the digitizer underneath does not burn. you have to lift the glass gently and bit by bit without putting pressure on the digitizer. suggest looking at Utube videos on how to replace glass on various mobile phones. If the digitizer is already damaged you have to replace the digitizer which is costly and involves pulling a mobile phone to pieces and re assembling it.
Jan 20, 2015 | Cell Phones
How do i replace the front glass on my w755 motorola cell phone?
In order to know how to repair the phone. You can contact us directly trough our Motorola Website trough our link:
Jul 01, 2014 | Motorola Mobility MOTO W755 Cellular Phone
Glass is broken. Want to chane the glass and the cover
YES AND ABOUT 100 QUID YOU CAN GOOGLE HTC REPAIR CENTRE FOR AN ESTIMATE
Dec 25, 2013 | HTC Touch HD T8282 T8282
Where can I find a Samsung repair center? in Orlando, Fl
Best place for Samsung repair (including Samsung Galaxy S3 and Galaxy S2 Screen / Glass repairs) is XpressFix and 1 Hour Cell Phone Repair. They are the place for cheap Samsung repair and Galaxy Glass replacement in Orlando, FL. Samsung Galaxy Screen Repair Orlando or try this site for Samsung Galaxy Glass Repair in Orlando, FL They also offer iPhone repair services.
Sep 03, 2012 | Samsung Galaxy Tab 101 Tablet...
How can I fix cracked screen
There is only one way to make your screen look better, but it will not "fix" the crack. I have done this and sometimes i cannot even tell my screen is still cracked and i didnt have to pay Apple $350 for a new piece of glass.
Here is what you can try:
1. Go to a auto parts store and buy a "Winshield repair kit" for small rock chips that look like a bullseye style chip.
2. CAREFULLY CLEAN THE GLASS WITH ALCOHOL and let dry for 10 minutes. Then heat up the glass of your phone with a hair drier for about 2 minutes so its hot, but not too hot to handle.
3. Then very, very slowly and cautiously, cut the tip of the nipple on the "epoxy/resin" bottle they have in the repair pack and while the phone glass is still hot (you may want to cut the tip of the bottle first, then heat up your phone), gentle squeeze the clear resin into and along the crack in your phones glass....Squeeze the resin directly along the entire length of the crack while attempting to squeeze it INTO THE CRACK...its diffucult, however, the heated glass will **** in the cool resin and actually fill in the crack.
Make sure not to get the resin on the phone or your skin!!!
AND BE PATIENT WHEN applying it.
ALSO, try to do this on a sunny day, because you have to place the glass in direct sunlight, or under a UV light to allow the epoxy/resin to cure. IT WILL NOT WORK UNDER A NORMAL LIGHT BULB. SUNLIGHT Actually works best.
Leave it in the sunlight for at least 1 hour or longer. Then wait another 24hrs before taking a razor blade to scrap off the excess resin that has built up on the glass.
FYI, it the crack to too deep the epoxy will seep thru the glass and this process wont work.
Jul 30, 2012 | LG Lucid 4g Lte Vs840 verizon Parts Or...
Hello, i have recently dropped my sony erricson xperia x10 phone and the glass screen has smashed. No actuall damage to the LCD screen as the phone works fine, i just have a cracked screen. I was just...
there are phone repair shops all over the place that can replace the glass quickly
the glass is fairly expensive but there are different qualities that increase the life of the glass on dropping
ask around , get quotes and consider having a person with experience do the job as it takes very little to break the phone full stop
Jan 30, 2018 | Sony Ericsson XPERIA X10 Cell Phone
I have a iphone 3g got a replacement glass to replace the cracked one but it is only the screen. Am I better of getting a screen with a digitizer?
I recently had the same problem. You can buy the glass by itself (which you already know), but then you would have to chisel away all of the glass from the digitizer which is really risky, difficult, and may ruin the digitizer in the end. If your dropped your iPhone 3G and the glass cracked, you will need to purchase a new glass display AND digitizer. They will come together as the digitizer will already be glued to the glass display. This will cost you about $70 before shipping. If you are doing the repair yourself, you may want to consider getting a pry tool to help you take it apart (about $4). There are some youtube videos by PDA parts that show you how to take apart the phone. I ended up getting my glass display and digitizer from Mission Repair, as it comes with the adhesive strips you will need to afix the display to the frame. I got my pry tool from PDA Parts. Due to the lack of information out there about what to do when the glass on your iPhone 3g cracks, I ended up making a website to help people out. Soon I will have a video tutorial and as well as written instructions with pictures on how to replace the glass and digitizer yourself. The site is http://3gcrackedglass.com Good luck with the repair!
Oct 17, 2008 | Apple iPhone 3G
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
