Question about Coffee Makers & Espresso Machines
MySaeco Magic delux, water lite continues to blink red after several attempts to drain the system
  • 105 Answers
SOURCE: NO PIX NO SOUND
I have searched high and low in all the documentation for your T.V., which is why it has been so many days since you posted your request for assisatnce.
Have you tried turning the TV on with both the remote and with the buttons on the TV? I'm betting you have, but I need to ask.
I would suggest that you unplug the TV for at least 24 hours to completely clear the memory of everything. This might reset the unit so that it begins working again.
However, my bet is that your power supply is dead so that it cannot power up the TV at all. Unless your TV is still under the warranty I think the only options you have are to either have the TV repaired by an authorized servcie technician or to buy a replacement TV.
Sorry I don't have better news to offer you.
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Posted on Feb 19, 2009
ginko
  • 19396 Answers
SOURCE: continuous blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 25, 2009
  • 70 Answers
SOURCE: I have a Magic deluxe and the water light is
magnet in the water tank may have died. This happens when water somehow gets into the magnet itself.
check www.saecooutlet.com for a replacement or contact them for a replacement part.
Posted on Sep 10, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Posted on Dec 03, 2009
After draining water several times the red lite continues to blink
you are draining water from your tv?? stop doing that
May 05, 2017 | Televison & Video
NO ICE, WATER LINE OK,RED LITE FLASHING NEXT TO ON /OFF SWITCH
The Model & Serial #'s would help me refine your answer.
I will assume you have either Whirlpool, Kitchenaid or
Sears Kenmore. The blinking red light should be binking as
a pattern of 2 blinks followed by a pause. then Repeats.
Lift the trap door and look at the icemaker, the 8 little fingers should
be parked at upright and slightly leaning forward towards you.
Carefully check to see if you have ice inside the mold behind and
below the fingers. If you feel a curved surface there's no ice..
Next precisely measure 5 ounces of water and carefully place
the water into the mold. Any where behind any finger.
Wait a couple hours and check if cube have ejected out into your
emptied bin...If after several hours and NO ice, most likely the icemaker has gone Kaput! Order and replace it. For detailed video go to YouTube and watch how to remove the icemaker.
Search using the words: Whirlpool In-Door Ice Maker Replacement.
Watch the video before attempting removal..Tricky.
Feb 20, 2015 | Refrigerators
My Saceo magic deluxe has issues. no steam or hot water will come out just a loud noise and the water light keeps flashing red but the tank is full. Please help
Machine could be scaled up. clean the steam and coffee outlets then descale whole system.Other possible causes could be a faulty pressure pump.
Mar 25, 2012 | Saeco Magic De Luxe Espresso Machine
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
I have a Magic deluxe and the water light is blinking
Jul 10, 2009 | Saeco Magic Espresso Espresso Machine
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
603 will not stop running liteas blinking!
try resetting it, unplug for 1 hour and then plug back in, another thing is check your manual or go to their web address
Oct 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe flashing water light, & not draining
The pump could be out or it could just need primed. Saeco sells a cheap hand pump that you insert into the receiver and force water into the system while the pump is pumping. This will often prime the pump and get things going. Call 1 800 933 7876 and tell one of the customer service reps you need a priming pump.
Aug 06, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
