Why can't i find fubo tv on my rook channel store
I already have netflix account, but just put rook stick on another non smart tv rook wants me to start another netflix account, how do i sign into the existing netflix account ?
the base account allows 2 simulations connections
eg : streaming 2 TVs same time.
to long in use your user name and PW
that is all there is to that.
no sign in to your account, unless, you like giving them free money?
no rooku does not
netflix, memorizes your device names .
so it can stream based on what it wants and needs
that means you need to sign in one time,
on each new device. used.
TV , rooku , DVD smart player. etc.
all are devices and very different.
so does vudu and hulu, i have all 3.
Jan 12, 2018 | Smart Computers & Internet
How do I turn of roku and go back to my satalitte tv
There is a "source" button on your tv remote, hit that button until you get to the correct source that your satellite tv is on.
Nov 24, 2014 | Roku Televison & Video
Easier instructions for Rook card game
Four players are organized into two teams of two players each, sitting opposite each other. Players must keep their hands secret from all other players, including their teammates. The object of the game is to be the first team to reach 300 points by capturing cards with a point value in tricks. If both teams have over 300 points at the end of a round, the team with the higher point total wins.
Only certain cards have a point value. These are known as counters. Each 5 is worth 5 points, each 10 and 14 is worth 10 points, and the Rook Bird card is worth 20 points.
The Deal The 1s, the 2s, the 3s, and the 4s should be removed from the deck, and the Rook Bird card should be added, for a total of 41 cards. The dealer shuffles and cuts the deck, then deals all of the cards, one at a time. After every player has received his or her first card, the dealer places one card in the center of the table. This is repeated until there are five cards (the nest) in the middle of the table. The remaining cards are dealt normally.
Bidding After the deal, players bid in increments of 5 points for the privilege of naming the trump suit. Bidding starts with the player to the left of the dealer and passes clockwise. The minimum bid is 70 points, and the maximum is 120 points (the number of points a team would make if they captured all the counters in the game). If a player chooses not to increase the bid, he may pass to the next player. A player that has passed may not make another bid for the round. The high bidder adds the five cards of the nest to his or her hand, then lays any five cards to the side. The high bidder then names the trump suit.
Play After the trump suit has been named, the player to the left of the dealer places any card of any suit face-up on the center of the table. Play proceeds clockwise, with each player playing one card face-up in turn. After each player has played, the player that played the highest card of the suit of the leading card takes all of the cards played, or "takes the trick".
A player must either follow suit (play a card of the leading suit) or play the Rook Bird card. If a player has no cards of the leading suit, he or she may play any other card, including the Rook Bird card or a card of the trump suit. The highest card of the leading suit takes the trick, unless a trump card is played, in which case the highest trump card takes the trick.
If a player reneges, or fails to follow suit when he or she could have, the error may be corrected before the next trick is taken. If it is not discovered until later, the round ends, and the team that made the error loses a number of points equal to the bid, regardless of which team made the bid. The opponents score all the counters they captured before the error was discovered.
The person who takes the trick leads in the next trick. When a trick is taken, it is placed face-down in front of the player who took it. Tricks taken may not be reviewed by any player until the end of the round. The player that takes the last trick in a round captures the nest and scores any counters in it.
The Rook Bird card The Rook Bird card is the highest trump card in the game. It takes any trick in which it is played.
You may play the Rook Bird card at any time, even if you are able to follow suit. It is the only card that may be played this way. If the Rook Bird card is led, all other players must play a trump card, if they have one. If the trump suit is led, and you have no other trump card, you must play the Rook Bird card.
Scoring When all possible tricks have been taken, each team adds the counters it captured. If the bidding team failed to make the number of points bid, the team loses a number of points equal to the amount of the bid, and does not make any points for counters captured in the round. The opposing team receives points for any counters they captured.
The first team to reach 300 points is the winner.
Aug 02, 2014 | Hasbro Rook Family Young Adult and Kids...
Far cry 3 cheats
Travel to the indicated location using the in-game map and the listed coordinates to find the corresponding place of interestfeature:
    Boat color cycle: X: 641.5, Y: 408.2 (travel to this location by boat; also does it on the ocean bottom) Dead body cave: X: 630.2, Y: 685.0 Flying fish: X: 756.3, Y: 634.3 (travel to this location by boat) Goldilocks and the Three Bears reference: X: 796, Y: 647 (three chests with bear claw marks) Inside the rocks: X: 721.2, Y: 747.0 (travel to this location by jet ski from town, and ride into the crevice at this location) Invisible water: X: 588.8, Y: 781.1 (walk near the nearby cliff to suddenly be underwater) Large cave: X: 331.8, Y: 458.1 Moray eels: X: 814.7, Y: 612.0 (search near the bottom; they will wrap around you) Ocean dry patch: X: 302.8, Y: 285.6 (travel to this location by boat, fall to the ocean bottom and walk around; try pushing the boat) Outside flashlight: X: 706.5, Y: 643.5 Rock slides: X: 702.2, Y: 783.4 and X: 465.6, Y: 665.8 (jump in the rock crevices at these locations and slide upwards) Table goat: X: 360.4, Y: 740.7 Treasure hole: X: 346.9, Y: 700.5 Underwater toilet and sick soldier: X: 807, Y: 637 Vultures: X: 377, Y: 793 Walk through wall glitch in "Mother Lode" mission: X: 684.3, Y: 731.3 (enter the mineshaft, then jump across to the piece of wood on the right wall, and walk through the wall here) Waterfall glitch: X: 678.1, Y: 635.7 (behind the waterfall, jump through the back wall; "Cargo Dump" mission location) X-ray glitch: X: 761.7, Y: 752.1 (in the Badtown store, jump on the counter, on the lantern, and jump across to the shelf; stand up and look around for a weird view)
  • Hidden cutscenesEvery time you travel to the grotto underneath the mansion, take one of the "eat me" berries to view a hidden cutscene.
  • Signature weaponsSuccessfully complete the indicated task to unlock the corresponding weapon for purchase. Note: All Signature weapons are rated five stars.
    AMR
      Type: Sniper Rifle Description: A customized Z93 with extended magazine, high power scope, and custom paint. Fires an explosive, penetrating round. Enhanced for damage at long range. Stats: Accuracy - Max, Damage - Max, Range - Max, Fire Rate - Fair, Mobility - Very Good Unlock: Find 20 Relics. Cost: $4,800
    Bull Shotgun
      Type: Shotgun Description: A customized M133 shotgun with extended shell capacity, and custom paint. Enhanced for damage. Stats: Accuracy - Poor, Damage - Excellent, Range - Extremely Poor, Fire Rate - Good, Mobility - Max Unlock: Find 10 Relics. Cost: $3,010
    Bushman
      Type: Assault Rifle Description: A customized P416 with optical scope, extended magazine, suppressor, and custom paint. Enhanced for accuracy and damage. Stats: Accuracy - Excellent, Damage - Great, Range - Very Good, Fire Rate - Superb, Mobility - Excellent Unlock: Activate all Radio Towers. Cost: Unknown
    Cannon
      Type: Revolver Pistol Description: A customized .44 Magnum with extended barrel, optical sight, 6 round chamber, and custom paint. Enhanced for accuracy and damage. Stats: Accuracy - Excellent, Damage - Excellent, Range - Good, Fire Rate - Good, Mobility - Great Unlock: Uplay Reward Cost: $2,700
    Japanese Tanto
      Type: Machete upgrade Description: The tanto is a Japanese dagger that was carried by the samurai. Wielding one of these will increase the damage dealt in melee combat. Stats: N/A Unlock: Find six Letters Of The Lost. Cost: $0
    Ripper
      Type: Light Machine Gun Description: A customized MKG with optical scope, extended magazine, and custom paint. Enhanced for accuracy, damage, and low recoil. Stats: Accuracy - Excellent, Damage - Excellent, Range - Excellent, Fire Rate - Max, Mobility - Good Unlock: Successfully complete six Trials Of Rakyat. Cost: $4,200
    Shadow
      Type: Pistol Description: A customized 1911 pistol with a larger magazine, silencer, and custom paint. Enhanced for accuracy and stealth. Stats: Accuracy - Max, Damage - Very Good, Range - Fair, Fire Rate - Very Good, Mobility - Excellent Unlock: Liberate 17 enemy outposts. Cost: $2,600
    Shredder
      Type: Submachine Gun Description: A customized Vector .45 ACP with reflect sight, suppressor, extended magazine, and custom paint. Enhanced for accuracy and damage. Stats: Accuracy - Great, Damage - Great, Range - Good, Fire Rate - Max, Mobility - Superb Unlock: Collect 10 Memory Cards. Cost: $3,275
  • Rare animal locationsSearch the indicated locations to find the corresponding rare animal:
      Black Panther: Outpost southeast of the mansion, Path Of The Hunter. Blood Komodo: Cliffside Overlook outpost, Path Of The Hunter. Golden Tiger: Mosquito Yard outpost, Path Of The Hunter. Maneater Shark: Kell's Boat Repairs, Path Of The Hunter. One Horn Buffalo: Camp Murder outpost, Path Of The Hunter. Undying Bear: Cradle Gas outpost, Path Of The Hunter. White Belly Tapir: Rust Yard outpost, Path Of The Hunter. Yellow Neck Cassowary: AM-12 outpost, Path Of The Hunter.
  • Letters Of The Lost locationsGo to the indicated coordinates, which are shown in the top right corner of your map, to find all 20 Letters Of The Lost:
    Letter 1
      Map: North Rook Coordinates: X: 435, Y: 646
    Letter 2
      Map: North Rook Coordinates: X: 363, Y: 710
    Letter 3
      Map: North Rook Coordinates: X: 460, Y: 767
    Letter 4
      Map: North Rook Coordinates: X: 380, Y: 741
    Letter 5
      Map: North Rook Coordinates: X: 530, Y: 742
    Letter 6
      Map: North Rook Coordinates: X:601, Y:621
    Letter 7
      Map: North Rook Coordinates: X: 682, Y: 811
    Letter 8
      Map: North Rook Coordinates: X: 630, Y: 646
    Letter 9
      Map: North Rook Coordinates: X: 633, Y: 602
    Letter 10
      Map: North Rook Coordinates: X: 703, Y: 575
    Letter 11
      Map: North Rook Coordinates: X: 799, Y: 750
    Letter 12
      Map: North Rook Coordinates: X: 801, Y: 756
    Letter 13
      Map: North Rook Coordinates: X: 778, Y: 619
    Letter 14
      Map: North Rook Coordinates: X: 603, Y: 458
    Letter 15
      Map: South Rook Coordinates: X: 471, Y: 418
    Letter 16
      Map: South Rook Coordinates: X: 529, Y: 400
    Letter 17
      Map: South Rook Coordinates: X: 408, Y: 499
    Letter 18
      Map: South Rook Coordinates: X: 375, Y: 315
    Letter 19
      Map: South Rook Coordinates: X: 237, Y: 426
    Letter 20
      Map: South Rook Coordinates: X: 497, Y: 501
  • Read more: http://www.cheatcc.com/ps3/farcry3cheatscodes.html#ixzz2nZadR1Vu
    Dec 15, 2013 | Video Game Consoles & Games
    GE 20GT320 TV
    don't use auto programme.
    use manual or semi auto.
    you have to press the auto programme button a few times.
    Jul 12, 2008 | GE 25GT270 TV
    TV not storing vcr channel
    most newer tv's wont store the channels if the channel isn't always putting out a signal. not much you can do about it
    Oct 31, 2007 | Televison & Video
    Televison & Video Logo
    Top Televison & Video Experts
