Question about The Computers & Internet
Hi there can a cf80acverb run on both the 12v supply and the 240v supply at the same time or must you use only one supply at a time
ltfrc
  • 227 Answers
SOURCE: powering tv
Read any information on the 240v to 12v adaptor. If the 12v is DC yes you can use the Battery direct. If it is 12ac no can do.
Mike
Posted on Mar 29, 2009
pra0099
  • 153 Answers
SOURCE: 12v 5a power supply failed
Give it to rewindind or replace it with new
Posted on Sep 18, 2009
novafire
  • 61 Answers
SOURCE: I have a Seagate ST3400601U2-RK external hard
Check the power adapter or the back of the hard drive where the power plugs in. Usually the DC voltage is written on either spots.
Posted on Dec 30, 2009
  • 6771 Answers
SOURCE: I need a new switching power supply In: 100-240V Out: 12V 5A for AudiosonicKM 1902 DVD. Where can I purchase
Try a computer repair store, or go online to Audiosonic to see if they can provide the part, finally! www.ebay.com Type: make and model, or the power supply number.
Posted on Mar 26, 2012
  • 105 Answers
SOURCE: Can a 12 v supply be used for ferg.f1604levd straight from a 12v battery
a 12V battery from car??
in cars battery are actually between 14V(fully charged) and 11V(empty)
else i don't know but the best way to be sure is using a regulator (this for example)
Posted on Nov 22, 2012
What switch position should I have for 12v & 240v in a millard 2002 van
The 12v & 240v switch is to change voltage supplied to the camper. You use the 12v if you are running things from the battery; you use the 240 when you're connected to what the US calls "shore power" or "land power"
Mar 24, 2015 | Cars & Trucks
No 12volt supply unless connected to 240v mains
the power invertor could be the peoblem, or the fuse to the `12 volt supply sockets
Nov 09, 2014 | RVs
Nov 21, 2012 | Computers & Internet
Can i connect my tele in mt caravan on 12v
Yes. Either by using a 12v dc tv, or if it uses 120v/240v ac by using an inverter on the 12v dc supply which ups the voltage and converts to ac.
Jul 14, 2011 | Televison & Video
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
Powering tv
Mike
Mar 29, 2009 | Televison & Video
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
