Question about Bosch Washing Machines
Washing machine BOSCH WAE 28481 displays error code F:61. What this error code means?
  • jkmarkku Jul 25, 2009
    The error code shown in the display was F:61, no else. I was washing crib bumper padhttp://www.ikea.com/us/en/catalog/produc... with "mix"-program. Error occurred before rinsing and machine emptied the soap water. I tried washing the pad again now with "eco"-program (can take bigger amount of laundry) and this time everything worked correctly, pad is clean now. I suspect F:61 might mean something like "could not find balance for centrifugal drying".
  • 1,272 Answers
there is no know error code like F61 on this machine. Check the below error codes;
Error Code: F32
Cause: Lower oven temperature sensor failure; An open or short circuit in the lower oven sensor wiring
Corrective Action:
1. Check all connections, especially P24 on the power
board.
2. Unplug the sensor connector and check sensor resistance (approximately 1080 ohms at room temperature with connector remove). Remember to reconnect it.
3. Check that neither sensor wire is open or pinched to the appliance chassis.
4. Check that the solder joints in header P24 on the power board are not broken.
5. If sensor is OK, replace power board.
Error Code: F41
Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring.
Corrective Action:
1. Check P24 connector on the power board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are
5. Check P10 connector and check if latch motor wire is
Error Code: F42
Cause: Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring.
Corrective Action:
4. Check P10 connector and check if latch motor wire pinched to the appliance chassis.
5. If F42 persists, replace power board.
Error Code: F43
Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring.
Corrective Action:
4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
5. If F43 persists, replace power board
Error Code: F44
Cause: Lower motorized latch will not unlock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring.
Corrective Action:
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
Error Code: F45
Cause: Upper (or single) oven latch both locked and unlocked; Defective or jammed upper oven door or latch switches.
Corrective Action:
1. Check P4 connector on the power board.
4. If F45 persists, replace power board.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 25, 2009
  • Anand Gupta
    Anand Gupta Jul 25, 2009
    Gud to know that information and happy to know that the issue was resolved.
    Regards
    Anand
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Why won't it heat up? And what does error code 311 mean
rcr311w codes Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > rcr311w codes
Zita http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes.html here is one link to error .
Sep 12, 2015 | Bosch HBL5450UC Electric Single Oven
Bosch WAQ24461SN Error code E35. Help please. Zita
here is one link to error codes not waq series but will give you an idea
here is a link to a nice little video how to make a good guess whats up and also the error code info you need
usually you find high up codes are something to do with sensors or flow rates on intake etc
sorry cant find the exact error condition you have
a quick phonecall to bosh service department and they can tell you they are very helpfull as a company
http://www.espares.co.uk/advice/0/2593/how-to-identify-an-error-code-on-a-bosch-neff-or-siemens-washing-machine-
Dec 02, 2014 | Bosch Washing Machines
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
E36 error code
My Bosch washing machine is showing error code E36 what's the meaning?
Feb 18, 2014 | Bosch Washing Machines
I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
Jan 06, 2013 | Bosch Washing Machines
Washing machine stopped and door opened and says E3. please help. machine is a bosch wae....
The machine identifies and indicates some operational errors through a series of beeps.E3 is also listed in that beep.the meaning of e3 is nothing but it is telling to call the service engineer.This error signal is due to Thermistor open/short.Thanks for your question.
Jun 19, 2011 | Washing Machines
BOSCH WAA24270GB error code 0 and 2 backwards rr
Press START button over 10 second, its working for me
Apr 09, 2010 | Bosch Washing Machines
Washing Machines Logo
437 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
