SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
SOURCE: RM115 Reddy Heater forced air heater problem
I had close to the same problem i drain the tank added new fuel still no diffrence so i removed the filter going to the tank pick up flushed out with brake clean it work fine for half a day . I knew then i was on the right track . I went to the local hardware store and bought a tune up kit that had the filter in it,I replaced the filter going to the tank pick up and it's been working fine even in cold weather. Fuel quality has a big part to play in it's abbility to burn in colder tempicures.
Posted on Jan 16, 2009
SOURCE: Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close.
Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
SOURCE: Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Posted on Aug 14, 2009
SOURCE: Dayton 3VE51 oil fired heater
Hi check for blockage in the flue check out the pressure switch, check heat exchanger
Posted on Feb 08, 2010
Mar 24, 2014 | Leisure HOMEPRIDE Electric Fireplace...
Jan 11, 2014 | Mr. Heater Natural Gas Garage Heater -...
Oct 19, 2013 | Atwood Mobile Products Atwood Water Heater...
Oct 13, 2013 | Water Heaters
Mar 15, 2011 | Goodman Heating & Cooling
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
Dec 09, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Oct 30, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Oct 15, 2008 | Heating & Cooling
Sep 06, 2008 | 1992 Volkswagen Fox
Apr 23, 2018 | Heating & Cooling
26 people viewed this question
