Question about The Office Equipment & Supplies
Install the new drum and wait for it to display the replace drum error.
    Habit-Forming:
    New Friend:
  • 81 Answers
You need to get experts support....Cal at customer support you can dial 800-243-0051 to experts.
Posted on May 05, 2017
3 Suggested Answers
  • 1684 Answers
SOURCE: Display an error OUt of Drum
The drum unit in your printer needs to be replaced. The drum is the pars that the toner fits into. You can take your old drum into Office Depot and they can get the right number for you if you can't find it printed on the top of the drum. The drum has a page print life and when the page count hits that number you have to replace it to continue printing.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
  • 22 Answers
SOURCE: Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Posted on Dec 07, 2009
How do I reset a drum life on a d-350?
I think you mean a DR350.
1. Install the new drum and wait for it to display the "replace drum" error.
2. Open the front cover of the printer as if to change the toner out. The printer will read cover is open.
3. Press the clear/back button or just clear. The printer will say "replace drum?
4. press the 1 button and the printer will read "accepted".
5. Turn the printer off then on again to fully clear the error. Upon restarting the printer you'll be good to go.
Jun 12, 2014 | Brother HL-2040 Laser Printer
"please wait" error appears on diplay when i turned on the mfp
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Nov 24, 2013 | Minolta DI2510 Black and White Copier
I have replaced the drum but still get a message that the drum life will end soon.
Open the front cover and press clear/back buttom
then press start
finally, press 00, then the screen will show accepted.
after that, you will be good to go.
Jan 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
Drum error message
To reset MFC-7840W drum count use the following steps.
1. open the front cover (leave open).
2. Press clear/back.
3. Then confirm the new drum install by pressing 1.
4. The display will indicate accepted.
5. Then close the front cover.
This should be done each time the drum unit is replaced.
Jun 18, 2010 | Brother MFC 7840W Printer
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Drum error. dont have user guide. how do i troubleshoot? tried replacing drum but still says drum error.
If the drum is used up you open the front door and press menu or options and tell it it's a new drum, otherwise you clean the metal contacts on the sides of the drum and inside the printer, and run the blue tab back and forth about 20 times. If still drum error you may have a bad power supply.
Jan 30, 2010 | Brother MFC 7840W Printer
HP CLJ 2840 - Engine error
It seems from the outside looking in that the drum may have frozen up the drive motor.
Remove the new drum and install the old drum and see the the error goes away.
Jul 06, 2009 | HP LaserJet 2840 Printer
I hope this helps,
Buddy
Corporate Computer
Jun 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Apr 19, 2009 | Panasonic KX-MB781 All-In-One Laser...
26 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
