Question about Lands Phones
My handsets show Do Not Disturb New CID10. Why did it come up and how do I get it off?
Reset Do not disturb
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND).
In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again.
Hope that helps.
Sep 18, 2013 | GE Dect 6.0 Phone Digital Answering...
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
GE cordless- back of phone says model number 5-2811. How do I get the "do not disturb" off so my phone will ring?
1. Pick up the phone handset and dial *98.
2. Press 1 to enable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been enabled, you may hang up the phone handset.
1. When you are ready to accept calls, pick up the phone handset and dial *98.
2. Press 2 to turn off Do Not Disturb. When you hear the confirmation you may hang up the phone handset.
Aug 10, 2009 | Uniden Cordless Phone
Ge cordless phone model #28111ee2-a,the face of the phone says do not disturb,how do i get it off?
CLICK HERE for your owners manual.
The Very Last paragraph states the following...
DND allows you to mute the ringer on all handsets.
In the standby mode (phone handset off and in cradle), press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 31, 2009 | Uniden Cordless Phone
My GE 5.8 cordless phone is in do not disturb mode . how can i get it back to normal
DND Allows you to mute the ringer on all handsets.
In the standby mode press the do not disturb button on the base the DND indicator will light and DO NOT DISTURB shows in the handset display.
To cancel press the do not disturb button again.
May 07, 2009 | GE 25952EE1 Cordless Phone
Phone set on do not disturb can not undo
For GE 6.0: There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz: 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Nov 12, 2008 | Uniden Cordless Phone
Taking off Do Not Disturb
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Hope this helps!
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
My GE Digital phone is on the do not disturb how can I take this off
For GE 5.8 GHz:
Apr 09, 2008 | GE Telephone pr521w
Phone on Do not disturb
For GE 5.8 GHz:
Hope this helps!
Jan 11, 2008 | GE 5.8 GHz Cordless CID Speaker Phone X 2...
Do not disturb
For GE 5.8 GHz:
Jan 02, 2008 | Uniden Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
