Question about The Office Equipment & Supplies
We have replace the drum again this show it - The Office Equipment & Supplies
Error sc300 on Ricoh mpc 7500. i replaced the drum unit and its fine but after two weeks the error came up again
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
Aug 26, 2016 | Ricoh Aficio Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
My printer says drum troubleshooting contact guide manual and maintence I did eveything but still not working
If the display shows drum error you can try cleaning it by following the steps below:
1. Open the front cover. 2. Pull the drum (black) and toner (gray) towards you, put a little force on it. 3. Remove the toner by holding down the tab on the side of the drum, then pull the toner out. 4. Use a dry lint-free cloth to clean the roller inside the drum unit. Make sure to remove any excess toner from it. 5. Put the toner back to the drum, make sure that it clicks, Reinstall the drum and toner back to the machine, 6. Close the cover.
If the display still shows drum error, go ahead and do the drum reset.
1. Open the front cover 2. Press the Options button on the control panel 3. The display should show "Replace Drum - 1. Yes 2. No 4. Press 1 to reset the drum count 5. Close front cover. The display should show the date & time
If still it shows drum error, The drum unit needs to be replace. After replacing the drum unit, do the drum reset again,
Hope this helps.
May 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
Resetting the Drum counter on a Brother HL-2040
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Changed Toner but its still saying "No Toner"
You may need to replace the drum this time. Usually after a few toner changes the drum needs to be changed to.
Apr 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Excess toner after ?overfilling cartridge w/ bulk toner
Did you refill the toner yourself or put a new one in or.......
Jan 01, 2009 | Dell 3000cn Color Laser Printer
23 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
