Question about PRINTER Office Equipment & Supplies
Ihave a printer laserjetP2055d stuck on initializing when i turn it on
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
Sep 26, 2013 | HP LaserJet 2840 Printer
Printer is stuck on initializing
to many reasons can do that
1- Formatter board
2- Firmware corrupted
if you would like gave more detail so can gave you the solution
Mar 21, 2013 | HP Office Equipment & Supplies
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
We have replaced the belt in oki c5950 printer and the warning light is still on and displaying Belt life error
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
May 10, 2011 | Office Equipment & Supplies
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
Will not do anything stuck on initializing!
Try a NVRAM initialization. Turn the printer off and before turning it back on hold down the right arrow and cancel buttons together while the device is powered back on.
Sep 28, 2010 | HP CP3525DN Color LaserJet Printer
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
Jun 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
look for small black levers, and see if they have a piece of paper on it, or if stuck
Jan 22, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
HP G85 is stuck on "Initializing"
Sounds like your main board has gone out on this unit. We can sell you a replacment board for $45 if interested. Its not too terribly hard to install.
Nov 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
