Question about Lands Phones
Hi, we have a 2 commax intercoms at our business. one is working perfectly the other has suddenly gone totally blank and no sound or visual. Power is on
SOURCE: Samsung Syncmaster 741MP
i workin in the factory in tijuana mexico this trouble sometime its the solder defective in the ic amp good look
Posted on Aug 29, 2008
consultel1
  • 860 Answers
SOURCE: My Intercom Extention shows busy. I have
With the exception of not being to dial out, it sounds like your DND or do not disturb button is on,The feature can be turned back off by either pressing the DND button again or entering feature #85.
Posted on Nov 28, 2009
bkamen
  • 18 Answers
SOURCE: AT&T 974 model small business system
If you didn't get an answer on this yet, by default 2 separate offices with phonelines don't come with any sort of intercom feature.
there ARE ways to get it, but you'd have to talk to your local phone company about options.
If you have Internet service, you'd have to setup or subscribe to a VoIP provider. Then it's easy to get that working. You would also need VoIP phones though.
-Ben
Posted on Dec 11, 2009
SOURCE: hi this is uday i saw movie in my compaq 610 model
try to reinstall your sound card
here's the link
http://www.opendrivers.com/downloaddriverurls.php
Posted on Jan 17, 2010
  • 713 Answers
SOURCE: Good Morning! I work for a
Hi,I had exactly the same problem. I tried re-registering the handset several times with no change. In desperation, I took the battery out of the handset for 5 minutes or so and unplugged the transformer from the wall. I reinstalled the battery and plugged the transformer back in and voila!all the phone line now works perfectly.
Thanks and goodluck
Posted on Apr 12, 2010
Intercom rings continuously.
Its transmetter section may damagae...repair the pcb circuit
Nov 06, 2014 | Radio Communications
I have a commax intercom (dp - 2hp model). There are two wires connected from the bell outside to the connectors 1 & 2 on the unit inside and the bell is working. There are another two wires connected to...
you just said where everything goes, so what's the question?
connector 5 goes to your gat actuator, 6 is power for the unit, obviously there will be 2 wires for each for a complete circuit.
Oct 04, 2013 | Radio Communications
Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
ouch, sounds bad...
possibilities~
1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
(press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
3) major error with the system, have a serviceman come out and take a look
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
Everytime that anyone calls the receptionist, her line is busy, How do I correct this issue? Thank you . Panasonic KX-T7630
A couple of ideas. Have the receptionist call you and verify that they are really at the extension you're calling. Then make sure you turn on Call Waiting Intercom on that phone. From the intercom on the reception phone, dial *7311 for Intercom and *7321 for Outside lines.
Now the phone will soft ring and visual indication when you get a second call if you're phone is busy.
If you've mapped a button to ring the receptionist and it's not working, you may have unprogrammed the button. That's reprogrammed by PROGRAM, the button and 1 plus the extrension (usually 101) and STORE or ENTER to save. PROGRAM exits programming.
Carl
Jul 22, 2010 | Panasonic KX-T7630 Corded Phone
Good Morning! I work for a small business that has 5 of the GE 2-9451 4 line phones with intercom. We were actually running two businesses out of the same office originally. Line 1 would ring in to...
Since you said line 3 was working for #2 company, i will suggest you put the line 3 back from where you removed it from. From the look of things the line might be the only line connected to be functioning. When ever you want to switch line since it is with intercom you will need to switch both side from where it is connected to where it is connected to, so that network connection can be achieved.
And on the other hand, the other line might not be working properly, that is why it was not connected or used.
Take care.
Apr 08, 2010 | GE RCA 4-Line Speakerphone
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Jul 09, 2009 | Samsung SGH-D500 Cellular Phone
WON'T BOOT UP
Try to removing the hardware parts like RAM, (Sound, Display & network cards if its not onboard)
Swap the CMOS battery with other IBm Pc you have.
Place the RAM back & try to power the PC.
Apr 27, 2009 | Computers & Internet
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Intercom feature not working
Is one of the 2 phones transformer plugged into a power strip? If so, try putting it directly into the wall, most power strips do not pass the signal properly
Mar 22, 2008 | GE RCA 4-Line Speakerphone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
