WHERE TO FIND ALL FUSSES ?
MY ELECTRICITY AT HOME INCREAS TO 330 v WHICH MAKE MY WASHING MACHINE WONT TURN ON
    Top Expert:
  • Washing Mach... Master
  • 12,650 Answers
Need to notify electrical /power company of voltage spike to house
Posted on May 05, 2017
My AEG OKO LAVAMAT 13.50year 2005 turns off after a few minutes washing
check your power cord for continuity (ohms). If your power cord checks good, I would look at either the noise filter board or the user interface board or main control board. Start with checking your outlet. make sure it is wired correctly with proper voltage and grounding. You can buy an outlet tester at Lowe's or Home Depot. Really cheap. Has lights on it that tells you if wiring, grounding and voltage are right. if that checks good, proceed to machine. If I can help further, look for me on 6ya
Nov 27, 2015 | AEG Washing Machines
Washing machine lights went out and now water is coming out of the door when opened. checked fuse in plug but still machine wont work
Turn fill water off soon.
Sounds like a major problem.
are you sure you have power at the outlet? check with other
appliance. Be careful water and electricity do not mix!
Check circuit breaker in the main panel. If poped try to reset
If pops again, call electrician.
Owner's manual troubleshooting?
No help, Call MFG customer service number.
Warranty? follow that route.
Feb 27, 2015 | Washing Machines
How do I reset my servis washing machine 1500 A+A if it wont do it itself?
Un-plug the machine from AC mains wall socket, and re-plug it back after an hour; or so. If you do this over-night will be better. The internal electronic control circuit will reset itself.
Nov 29, 2014 | Washing Machines
I have a Sunbeam EM6910. The machine wont power up at all. Is my circuit board likely to be fried? It is 6 years old and perhaps not worth fixing?.
could be any number of faults but at 6 years old it is not economical to fix. How much did you pay and how many coffees in that 6 years... And what else did you learn....
Do some research and get a new system.
Jul 18, 2014 | Sunbeam Cafe EM6910
Zanussi ZWF 1437W.Came home,cycle finished but smell of burning, when put another load in panel wont light up and crackling sound
Seriously. Disconnect from the mains RIGHT NOW.
Water and electricity are always a bad mix and it sounds like your machine may be combining them right now. Worse still, if it's not water leaking, (which will kill you very nicely if the chasis goes live). then something inside is shorting without the aid of water, which could result in a fire.
Once you have unplugged and made safe, take the top off the machine and have a look and a sniff, then come back here and ask some questions about what you have seen.
Jun 28, 2011 | Washing Machines
Door wont open
Most washing machines electromagnetically lock when on a cycle and remain so for a few minutes after it has finished. If you turn the electricity off/switch it off before it has unlocked, the door may not open.
Try turning the power on for a few minutes and see if it will release. If that doesn't work, put it on the shortest cycle, eg spin and wait for it to complete before you turn it off
or check their is no water in the drum, if their is check the drain pipe isn't creased.
If not pull out your machine if reqd , and check the pump is not blocked, more common than you think. Can be located at the front or back of your machine.
If none of these turn off your socket for 10 mins.
Apr 30, 2011 | Washing Machines
The washing machine wont drain out , but will
Could be , you could remove pump and put two wires onto to check but be carefull Electricity kills..Could also be feed to pump from machine,Check 1st nothing is sticking blades , which is most likley
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
My washing machine is not working??
  1. Fixing an Agitator One of the most common problems with a washing machine is due to a broken or malfunctioning agitator. The agitator is the piece of plastic that moves back and forth. In order to fix the agitator, you must first remove it. If the agitator is not broken, but moving slowly in one direction or not at all, this can be due to the clutch assembly that the agitator relies on. You can remove the agitator and check the clutch assembly. The clutch has dogs that depress and pop up with each turn, however if these dogs are worn, they will need to be replaced. You can usually contact your washing machine manufacturer and order replacement parts. Alternatively, you could get one from a home improvement store that stocks common washing machine items.
  2. Electrical Problems Sometimes a washing machine may have electrical problems that can include a blown fuse, a broken timer, switches that are not functioning, etc. Obviously, before you fix a problem with the electricity, make sure you unplug the washing machine. First, check your fuse box and your electrical outlet. Some types of washing machines require higher voltage to work and it might be a problem with your home’s electricity rather than the washing machine. In addition to checking the outlets and fuse box, check the cords and electrical system of the washer machine. Most washer machines will have fuses that are accessible from behind the unit. Check to make sure all are working properly. If you are having a problem with a specific switch such as a timer or thermostat, you might want to check the connection or replace the timer or thermostat completely. Usually this only requires a screwdriver and the new part.
  3. hope your problem will be solved
Jul 20, 2009 | Washing Machines
Machine wont complete a cycle, it clicks once then stops
try to preceed manually to next program and if this problem repeat then the timer has problem chang it my advice donot try to select program during electricity connected to timer thank you
Jun 07, 2009 | Whirlpool AWM5145/2 Front Load Washer
Electricity goes off when machine start turning
it may be the motor if you unplug the motor then try again,if the power doesnt turn off then its the motor.also check for water leaks
Feb 28, 2008 | Siemens WXLS162 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
