Question about Dryers
My remote control on my ceiling fan is not working it has four numbers were the battery is at i need instructions on how to use it it won't program
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
  • 8 Answers
SOURCE: Program codes for tv and satelite.
The manual
Posted on May 25, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Posted on Dec 22, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Hunter ceiling fan. Remote control. Lights work, fan won't. Batteries in remote new.
If the fan came with a remote you probably need a new receiver. You can order at 1-888-830-1326. Need model #
Jul 07, 2013 | Dryers
Remote wont work for fan. You may need to reprogram the remote
May 15, 2013 | Televison & Video
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Remote missing on a Hunter Ergonomic fan. do not know how to take the base cover or light cover to see serial number. light cover has screws with no slots. base cover has no sign of srew holding it up. How...
Purchase the remote control, install batteries, and try it before taking anything apart. If the new remote control does not work, the internal receiver may have failed.
Dec 07, 2017 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote for Ceiling Fan (Model: AC 552 AL) no longer works. I changed out batteries and still does not work
Maybe it needs to be reprogrammed after new batteries. What is the model number on the remote, please?
Jul 12, 2010 | Hunter 52" Ceiling Fan With Light And...
My fan is remote controlled by a Hampton controller. The 9 volt battery died, I changed it but can not get it to turn on the light or the fan. The red light on the controller lights but no responce from...
Hello. What you will find is that there is a battery in the ceiling box [where the wires are connected] as well as in the remote control. My bet is that the battery in the ceiling box also needs to be changed. Hampton Bay products all come from the home depot. Go there if you need instructions, they should provide them to you.
Dec 14, 2009 | Universal Remote Control Hampton Bay...
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Dryers Logo
26 people viewed this question
Top Dryers Experts
