Question about Baumatic Ovens
Hi, I have a Baumatic 6009-P oven. It is displaying "1" , and I can't use the oven. So, I can't bake or use the oven. Please help!! Thanks, Laura
SOURCE: mabe oven
Hi, well i have researched the mabe oven problem and it turns out that mabe used to make a 110V oven bake element for the ovens made in Mexico. However it appears that they no longer make that model oven and it's parts. Isn't that just golly gee terriffic!I am still searching for an element for it as GE who is also a share holder about 42% worth also has parts that sometimes will fit the Mabe made in Mexico, and not to be left out of the programe Camco is also part of the GE Mabe family so they are also a source to check with, and yes even whirlpool who is nothing to do with any of those other than a competitor sometimes has parts that will fit the Mabe made in Mexico. I'm not saying it will be a perfect fit but if it works, it works, but i'm not recomending you do it to a customers appliance at least not without asking if it's ok.
Posted on Feb 20, 2008
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Posted on Mar 29, 2008
  • 3463 Answers
SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Posted on Dec 31, 2008
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Posted on Jan 24, 2009
  • 8197 Answers
Try this site
Good Luck and Please Rate FixYa!
Posted on Mar 08, 2009
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
Hi I brought a Baumatic Microwave model GEM252TK and I need the spec to fit it in to my new kitchen and I cant find it cheers
You can download a brochure - with the dimensions of the microwave - free from here:
The dimensions are at the bottom of page 25. You can view, print and or save this file. If you need the general specs e.g. power rating/features, you can find them here:
Please rate this solution if you find it helpful. Thanks.
Oct 23, 2010 | Ovens
Oven has stopped heating up
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Dec 07, 2008 | Baumatic Ovens
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again hope this helps
Jan 13, 2008 | Ovens
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
27 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
