Question about Acer PD116 Multimedia Projector
Menu settings control inoperative.
The remote control and those on the case except lamp on/off are inoperative and have been so virtually since new . As this projector was purchased in Singapore I have not had any help from acer uk.
  • 1 more comment
  • Anonymous Apr 07, 2008
    Same here. Remote control buttons are not working and buttons on the case either
  • rolandh Dec 21, 2008
    Same problem
  • Anonymous Jan 10, 2009
    Exatlely the same problem for ACER PH110
I have the same projector and after I thought it is faulty, I finally solved the problem by putting a signal on the input. With out the signal the unit will only switch the bulb on and the menu wont be available.
Hope this help
Posted on May 08, 2009
How do you find the menu setting? I dont have the remote. There is no other button but the power button on the projector. Help!
Posted on May 19, 2012
Blinking power button
follow this test and fix it. GOd bless you
You simply need a screwdriver (Phillips-head) and then follow this guide:
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
  • Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
  • Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Nov 04, 2013 | Toshiba TP50G50 50" Rear Projection...
Volum keep going off on my LT52153 mitsubishi tv
make this ttest and fix it. God bless you
Nov 04, 2013 | Televison & Video
2002 envoy code co550
you need to replace the tccm and get it programmed.
2-04-21-006E: Inoperative 4WD/AWD Lamps, Inoperative 4WD/AWD System, DTC C0550 Set No Communication with TCCM (Reprogram Transfer Case Control Module) - (Jul 20, 2006)
999999995.gif Subject: Inoperative 4WD/AWD Lamps, Inoperative 4WD/AWD System, DTC C0550 Set, No Communication with TCCM (Reprogram Transfer Case Control Module) Models: 2004 Buick Rainier 2002-2004 Chevrolet TrailBlazer, TrailBlazer EXT 2003-2004 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2002-2004 GMC Envoy, Envoy XL 2003-2004 GMC Sierra, Yukon, Yukon XL 2004 GMC Envoy XUV 2002-2004 Oldsmobile Bravada with Electronic Shift or Active Transfer Case (RPOs NP1, NP4 or NP8)
This bulletin is being revised to add Subject information and change the labor operation. This bulletin cancels and supersedes Bulletin Number 03-04-21-006. Please discard Corporate Bulletin Numbers 02-04-21-006D and 03-04-21-006 (Section 04 -- Driveline/Axle).
ConditionSome customers may comment that the 4WD/AWD indicator lights on the selector switch do not work, or the 4WD/AWD system may be inoperative and/or the service 4WD light is illuminated. The condition is typically intermittent and always occurs at key-up. Upon investigation, the technician may find DTC C0550 set.
CauseThe Transfer Case Control Module (TCCM) has not received the wake-up call during key-up and has remained in the "sleep mode".
When the TCCM is in the "sleep mode", it will not communicate with the class II bus or the Tech 2®.
Correction
  1. Try to communicate with the TCCM. If no communication, go to step 2. If communication is possible, go to step 5.
  2. Remove the underhood (ATCM or TREC) TCCM fuse.
  3. Wait 30 seconds.
  4. Reinstall the fuse. The module should "wake up" and communicate with the Tech 2®.
  5. Check for codes in the TCCM. If a C0550 is found current or in history with or without other codes, replace the module and go to step 6.
  6. Reprogram the TCCM with the latest TIS software using normal SPS procedures.
  7. Verify operation and that no codes are present.
Important: For the 2002 model year, the TCCM must be replaced and reprogrammed.
Warranty Information
Jul 29, 2011 | 2002 GMC Envoy
Can't reset lamp timer for new bulb
when you replace old lamp with new one the lamp timer not reset automatically the counter is a software data and you reset manually with remote control
HOW :Connect the power cord to the projector. The ON/STANDBY indicator light in red
Use remote control and press the following key on the remote control in following order for less than five second each.
RESET +LEFT ARROW KEY+ RIGHT ARROW KEY+ENTER (as show in picture)
Feb 10, 2011 | Sony VPL-ES2 Multimedia Projector
I follow all the steps to reset the filter time and lamp time with a new bulb but it will not reset any ideas
This Projector is controlled by an internal microprocessor. Under certain exceptional circumstances, the projector may not operate correctly and the microprocessor will need to be reset. In such a case, please push the Restart switch by using a cocktail stick or similar and before turning on again, make the projector cool down at least 10 minutes without operating. Only push the Restart switch in these exceptional instances.
Jan 03, 2011 | Hitachi CP-S335 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Lack of red tones in the co;or
In ur remote push the menu button.Got in menu Picture go down to reset.Push it should reset back to factory setting.
Mar 17, 2010 | Mitsubishi WD-62327 62" Rear Projection...
A power-outage left our Acer pd100 inoperative. When I tried plugging the projector into a power outlet once again, we lost power in the entire building. Is this a question only of purchasing a...
sounds like it, unplug the projector remove the lamp put the covers back afterwards and plug it in and switch on. If the electric in the building goes off without the lamp then your projector has a electrical fault that needs sorting. If the electric stays on then the lamp has blown causing a dead short causing fault conditions which will trip the main fuse if it is rcd or rcbo.
Feb 11, 2010 | Acer Office Equipment & Supplies
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
How do i replace the bulb in an LG rear projection tv RE44SZ21RD
Note: Wear cotton gloves when handling the lamps as it contains mercury.
  1. Remove the access cover behind the On/Off switch at the bottom of the rear cover by removing the 2 screws using a Philip screwdriver.
  2. Behind the cover is a metal box with a handle that protects the rear of the lamp. Remove the securing screws and pull the box with the handle.
  3. Remove the cable screws and pull out the plug.
  4. Remove the lamp clamp screws and lift the lamp
  5. Put the new lamp in place of the old lamp in reverse sequence of the above.
  6. Dispose the old lamp properly.
  7. Reset the lamp timer.
  • Make sure the TV is on.
  • Press and hold Menu button on the TV set.
  • Press and hold Menu button on the remote control at the same time
  • Hold the buttons until the service Menu pops up.
  • Release the Menu button on the remote then on the TV set.
  • Press and hold Enter /Ok on the TV set then press and hold Mute button on the remote control.
  • Hold the buttons until the Lamp Life Hours screen pops up.
  • Release Mute button on remote then release Enter/Ok on the TV set.
  • Press Select twice to confirm the reset of the counter.
Oct 09, 2009 | LG Televison & Video
Acer PD116 Multimedia Projector Logo
830 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
