Question about Whirlpool Washing Machines
Hello I have an ERROR F08 on my WHIRLPOOL 6TH SENSE WASHER, what can I do to have it restart?
    New Friend:
  • 165 Answers
Take filter out clean and replace that should sort your problem
Posted on May 05, 2017
SOURCE: Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Posted on Oct 13, 2007
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
GodBlessU
  • 3513 Answers
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Posted on Jul 30, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
  • 6277 Answers
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Whirlpool washer f08 e02
An F08 E02 error is a dispenser motor error on many Whirlpool washers. This could be due to dried detergent clogging the dispenser. Take the dispenser out and clean it following the directions in your manual. (Add a comment with the model number if you need a link to the manual. Most Whirlpool manuals are available on their support page: http://www.whirlpool.com/manuals/ .)
If that doesn't fix the problem or is only a temporary fix, the dispenser motor/switch may be faulty or the linkage between the motor and the dispenser may be blocked from moving freely. Alternatively the wiring may have a problem with a conductor in the wiring harness. Inside the top panel of the washer is usually a guide for checking the error. (The back panel has to be removed to get to the top panel and this information.)
I hope this helps.
Feb 19, 2015 | Whirlpool Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool 6th sense washer displayed f09 so I left it. next day it seemed OK but does part of the wash and comes up with FA
Thank you for your response. I finally managed to contact someone at Whirlpool who advised that the error code FA indicates a component problem and may require a replacement part. Unfortunately a serviceman is required.
Jan 29, 2010 | Whirlpool Washing Machines
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
