Question about Garden
Why is the cutting blade belt on a husked riding mower getting spliced?
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Blades will not engage on huskee LT4200
Probably the PTO cable is either coroded up and struck or it is broken. You will need the 13W model number from serial tag to look-up as there is at least 2 different cable for this model series.
Feb 27, 2015 | Huskee Tractor Replacement Riding Lawn...
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
When engaging the blades tractor turns off. Belt
sounds like you have a safety switch problem,, check the one to the under seat make sure it is pressed in,, if it is broke cut and splice wires together,, ( but when you do this the cut off wont work when you get up off tractor,if you want the switch to work get a new one) hope this help you,, good luck
Aug 14, 2009 | Garden
Craftsman 42" riding lawn mower blade free spinning but wont cut
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
