Question about Jabra Radio Communications
My jabra storm heaset is paired with my Kogan Agora phone. when the phone rings i have to manually answer the call. I used to answer with voice comnmands
  • 181 Answers
SOURCE: Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Posted on Dec 18, 2007
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
SOURCE: how do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Posted on Sep 09, 2009
  • 1932 Answers
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Posted on Nov 12, 2010
  • 1932 Answers
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
Thank You
Posted on Nov 15, 2010
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 | iPhone Apps
How does a regular headset work? I plugged it into the back of the phone, but don't know how to make it pick up...
if the headset is a wireless one there is a button on the headset itself you need to press to pick up or hang up a call. alternativly look for a headset or pick up button on the phone needs to be pressed. this i diffulcult to answer further without knowing the model of your headset.
download user manual for the phone at the following
check page 23 regarding using heaset.
when the phone rings press the headset feature on your phone and then select the ringing line button.
then press cancel to hang up.
I hope this was useful.
Jan 05, 2011 | Mitel 5220 IP Phone
Jabra 2050 wont pair with blackberry storm
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step. Pls come back and let us know if this solved your problem.
Sep 05, 2009 | Jabra Bluetooth Headset with Adjustable...
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
It is all in there
Jul 18, 2008 | Lands Phones
Jabra Bluetooth Setting
You have to pair the two devices first.
Use your phone to detect other bluetooth devices, when it finds the model Jabra you are using select it. Reset it before you start.
Jan 11, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Radio Communications Logo
32 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
