Question about Shimano Cycling
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
  • Shimano Master
  • 1,119 Answers
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
Posted on May 05, 2017
  • 6 Answers
SOURCE: Shimano Tourney rear derailleur is stuck on
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Posted on Aug 30, 2009
  • 484 Answers
SOURCE: Alivio 8 speed rear derailleur cable broken
There is a bolt on the derailleur that holds the cable. Loosen it to remove the cable from the derailleur. If there is a cap on the cable, remove it by pinching it with a pair of pliers. i do not know what style shifters you are using, but most all of them have a plastic cap covering the port for the cable. Shift to the highest gear to prep the cable for release and remove the cap. Push the cable back into the shifter and it should come out of the port you opened. Now, slide the new cable in and pull it through its circuit of cable housings and back to the derailleur. Attach the cable and shift to the lowest gear (big cog). Now, pull the cable along the top tube or seat stay (wherever it is more accessible) away from that tube very firmly several times. This pre-stretches the cable and minimizes necessity of adjustment later. The harder you pull, the better. Once you have stretched the cable, shift to the highest gear again and release the cable on the derailleur. Adjust the barrel on the derailleur to the center of its range and turn in the one on your shifter all the way. Now, pull the cable taut and reatach it on the derailleur. You can cut the cable to length and put a cap on it now. Shift into your middle gear and use the barrel adjuster on the derailleur to align the jockey wheel over the appropriate cog of the cassette. You should be all set!
i hope this helps
-matthew
Posted on Nov 15, 2009
  • 1788 Answers
SOURCE: I need to buy a Shimano RD-TZ30 bike rear
Go to your local bike store, they sell Shimano and as long as it will accomodate your cog you are set.
Posted on Oct 05, 2010
Coachphil
  • 347 Answers
SOURCE: Describe your shimano xtr rear derailleur spare
Broken inner plate can be a potential warranty. Contact your local bike shop and they can process the warranty for you, if it isn't a warranty then the same shop can order you a new plate.
Posted on Dec 12, 2010
  • 388 Answers
SOURCE: Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Posted on Apr 15, 2014
Testimonial: "Thanks - that's spot on, my little girl will now be having fun on her bike in no time!"
Can I replace a Shimano RD-TY15 with Shimano Tourney TX?
Main thing with gears is that they have the same number of gears, and that the cage is the same length. Also the RD TY15 has a built in hanger.
The Tourney pictured has a built in hanger (below link) just make sure the replacement does.
SHIMANO TOURNEY TX 55 Rear Derailleur with Hanger Virtue Bike
Apr 24, 2015 | Shimano Cycling
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
487 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
