Question about Samsung Televison & Video
Samsung 32 inch TV LA32C450E1XUM started with double image problem
It could be a very common problem with LCD TVs. The image is showing as doubled say a text showing twice, one few mm below other. I believe this is not the problem with the LCD panel. If firmware upgrade would help or this is a hardware issue. Kindly help
MikeNJ1964
  • 398 Answers
SOURCE: double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Posted on Sep 11, 2007
mcomijohns
  • 477 Answers
SOURCE: Nikon Coolpix L11 - LCD screen shows double image
It could be a loose LCD connection carefully take off the back and lift the LCD very carfully you will see the ribbon cable lift the tab take out the LCD and reinsert it and push the tab back down. If this does not fix it you might have a damaged main board its one or the other.
Posted on Apr 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: double image
yes you just need two ICs
Posted on Jul 12, 2008
SD Tech
  • 14553 Answers
SOURCE: double image shows in red
it is quite fixable and usually in your home; it is called convergence--kp57wv500 uses two STK 392-560 convergence Ic chips; both and any bad fuses or resistors around them need to be replaced and the set adjusted after.
I fix a lot of these sets in my area---if you call a shop you will pay 300-400----a lot of independent people will do it for under 250 in your home--shop around--now is the slow time of the year for tv shops---you could buy both IC chips on ebay for less then 13 dollars plus shipping---this is a normal problem in all projection tv sets--the chips have a white grease on the back of them designed to transfer heat--after several years it drys out and one of them goes bad---repair should take about an hour or so in your home---you should ask yourself if 200-300 dollar repair is worth while, could you replace the set for this? If the chips are replaced and the set adjusted they should be good for 4 or 5 years at the least.
I do this here for free so if this has been helpful give me a vote here. If you have questions or need more help here is my email:
etower.766@netzero.net
Posted on Aug 19, 2009
Testimonial: "Thanks for the detailed advice. Will look into it repair, but plasmas look so nice these days!"
asnowman
  • 788 Answers
SOURCE: the tv screen shows double images
Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board2.gif. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 14, 2009
Samsung 5 Series, 32 inch LCD tv shows double image and picture flickering.
You don't have to take your set to a technician its in the TV settings which you put your self,so use the remote go to TV menu then picture settings you will see that feature then and disable it thanks.
Nov 22, 2016 | Samsung Televison & Video
Sony KLV-32S550A LCD TV double image.How to fix
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 21, 2016 | Sony KLV-32S550A 32 inch Multi-System LCD...
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
Samsung tv displays doubling images
You have a faulty LCD panel, common with older Samsung and Sony sets!
Apr 06, 2014 | Samsung Televison & Video
I'm having double images with my RCA 32 inch lcd flat screen tv
You could try to go into the settings and use the "Image Cleaner" option. That's what we do with our tv. But i'm not sure if it will work with yours... (:
Dec 21, 2010 | RCA L32HD31 32 in. LCD HDTV
TV won't come on.. 32 inch LCD. purchased July 2007
Mine is kinda tempermental also. When it won't come on or turn off with the remote ,or gets a double image on the screen,I have to unplug for a couple of minutes and then it starts to work. Don't know why.?
Give it a try
Jan 07, 2010 | Niko SV3206 32 in. LCD Television
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
