Question about Garden
I have oil leaking out of lawn mower, is it as good as stuffed or can it be fixed?
    Top Expert:
  • Garden Master
  • 47,657 Answers
Depends where the oil is leaking from
more detail would be helpful
Posted on May 05, 2017
My 22inch weedeater lawn mower has a oil leak how do I fix it
Where is the oil leaking at? I am assuming if you park it it leaves an oil spot under the mower, If this is the case you need to replace the bottom crankcase oil seal (the seal where the crank come out the bottom of the oil pan).
Hope this helps
Aug 25, 2014 | Garden
How to fix oil leakoro mower leaks oil on deck
Check the oil fill tube if equipped, there is an o-ring at the bottom of the tube. If the oi is coming out of the muffler the rings are shot on the engine. Replace the engine. Is the oil over filled?
May 27, 2014 | Toro Power Lawn Mower
How to repair my dynamark riding lawn mower oil leak
need more info on where it leaks .that's an older mower it could be the oil pan or it could be the oil seal or it could be the pcv valve cover leaking or ?
May 01, 2014 | Yard Machines Garden
HOW DO I FIX THE OIL LEAK COMING FROM UNDER MY GXV 120 LAWN MOWER ENGINE?
Depends where it is leaking from, wash it off to see where it is coming from, it may well be the bottom crankcase seal, once the blade and carrier are removed you should gain acess to this, if it is leaking you will need to remove the seal and replace.
Oct 07, 2012 | Garden
My son may have ran over some damp grass with our Briggs and Stratton 500 series, 158 cc lawn mower and now it smokes and leaks oil out of the exhaust, how do I fix this?
if he tipped it on its side to clean the grass off the oil will burn off but check the oil level he just tipped it so the crank case drained into the cylinder also check the air filter that might have got oil soaked as well
Jul 09, 2012 | Garden
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
We have a yard man model 565 21" self propel lawn mower and we are having and oil leak, How can we fix it?
clean the engine first and run to see were the leak is coming from. The remover the engine to service the leak. I would have a trained Lawn Mower tech perform this work for settings will not be the same if done by yourself.. Marking all locations of springs and the governor settings are critical
Jul 09, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My daughter added oil then proceeded to mow the lawn. mower started smoking then quit. When I got home from work I was able to start the engine one time and it smoked a lot. I turned it off and have not...
With the engine cold, check the oil level. Oil level is quite important especially in a smaller engine. Try to clean all excess oil off engine and body. Then, if you can get it running....check for any leaks. If it is still smoking, it has other issues besides being too full of oil. The oil breather will be full of oil. The oil filter may be saturated with oil. Check those 2 things especially as they allow motor oil to be drawn into the carburetor and cause excessive smoking. Pull out and clean the spark plug. Post back if needed.
Aug 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
