Resting the toner ctridge
Once i refill the toner, it coulldn`t be recogonized by the printer.red led always blinking after warmed up the printer.
    Problem Solver:
  • 6 Answers
Yep, some cartridges have a lockout chip that restricts the print of more pages once the maximum rating has been reached. Since you have refilled the toner cartridge, I would have expected the seller to mention that the page counter needs to be reset by replacing the lockout chip with a "reset chip" so it can print again. Here's additional info on that:
http://lasertekservices.blogspot.com/2009/08/why-replace-reset-chip-of-toner.html
Posted on Nov 04, 2009
    Brigadier General:
  • 4,090 Answers
You dont say what brand or whether you have used refills before. Some laser toner cartridges have a chip on them that has to be reset.Refilling does not fool the printer i'm afraid. Contact the seller of this brand and check out how to overcome this
Posted on Jul 25, 2009
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
Feb 03, 2011 | Samsung ML-1640 Monochrome Laser Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
In samsung ML 1640,when the toner i refilled not
You can replace toner for that printer only with genuine Samsung toner because refilled toners are not working.
Feb 23, 2010 | Samsung ML-1640 Monochrome Laser Printer
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
Hiw do I reset the
The following conditions can cause the On Line LED to glow:
* Printer paper is jammed inside your printer.
* A cover is not be closed properly.
* The toner cartridge is not inserted properly and needs to be reinstalled.
* The toner cartridge is running low.
* There is no paper in the paper tray.
* The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. For replacement cartridges, please click here to visit our official online parts distributor.
On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service
Apr 14, 2009 | Samsung ML-1640 Monochrome Laser Printer
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Toner showing empty
first, if you refilled your toner, the printer will always tell you, that you are not using original toner and red light will blink. second, if printer tell you every time to replace different color, then you need to clean a chip reader and chips on toners. take out all toners and pc drum. under toner rack there is a chip reader, clean it with pressure air and reinstall
Jun 03, 2008 | Konica Minolta magicolor 2400 Laser...
871 people viewed this question
k24674
jasbo
jasbo
