Question about Sewing Machines
Pieces of Elma eling21 to put together in machine
Bobbin was loose so took it out then inside part came out, need to put it back!
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Posted on Feb 27, 2008
SOURCE: putting the bobbin housing back together
Found your problem while I was trying to solve mine. I can solve yours. Here is the page from my manual about how to remove/replace bobbin housing. I hope you can make this image larger so you can see it clearly. We're limited as to the size of the file we can upload.
Posted on Apr 13, 2009
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
The area behind the bobbin is in pieces, how do I put it back together. I have a kenmore.
do you have the book? it should show you how. if not take the pieces out that are loose and lay on a flat surface, now put together as if it is a puzzle, it will only fit one way. look to see if anything looks like it broke off rather than fell off. if nothing looks broken lift your machine up and lay on side so bobbin hole is facing up and see if you can lay the parts in as you put them on the table, if they don't snap into place look as see if maybe a small screw might have fallen out. hope this helps good luck.
Jun 15, 2017 | Sewing Machines
Putting bobbin pieces back into machine
I think your machine timing is changing . So you can not put the bobbin case. Please adjust or change the timing set.
Mar 26, 2014 | Sewing Machines
Put bobbin parts back together
What machine are you using?
Jan 28, 2014 | Sewing Machines
I cant put the inside of my machine back together
what is the name and model number of the machine ?
do you have a manual?
Dec 03, 2012 | Bernina Sewing Machines
I took out the inner workings of the bobbin holder underneath the machine to try to clean out some clogged up thread, but I can't seem to get it back together. Suggestions?
You should have 3 pieces that make up the parts of the hook and bobbin case that you can take out to clean. 1 the bobbin case, 2 the race ring, 3 the hook. The easiest way to reinstall the hook and race ring is to tilt the machine and lay it on it's back. If you have the bobbin door open, and you rotate the handwheel and look inside the hook area, you will see the driver rotating back and forth. You want to set the hook inside the hook housing facing opposite the driver. As if your putting two halves together. Next install the race ring, shinny side out. Most of the rings have a nipple at the bottom that fits into a slot in the hook housing. Next lock the race ring in place with the 2 black or chrome arms that you swing inward. All you do next is install the bobbin case. Your done.
May 01, 2011 | White Sewing 1755 Mechanical Sewing...
Sewing machine motor seized up and broken parts near bobbin
Without actually seeing the problem myself I would only be guessing. I would recommend taking it to a Sew & Vac shot and get their opinion and a repair quote.
Nov 22, 2017 | Kenmore Drop-In Bobbin 16231 Mechanical...
I took apart the bobbin part of my kenmore machine and can't get it back together
if you look in the well where the bobbin is supposed to go do you see two white pieces of plastic with a red hyphen on them...one on either side? if so, take a small pointed object and pull the red hyphens toward the center of the well. put the assembly back in the machine (it will only go one way, so be gentle. when you get it lined up, it will drop in). then push the two white pieces back away from the center with your finger. drop in the bobbin.
Mar 03, 2010 | Sewing Machines
I took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Jan 24, 2009 | Kenmore Sewing Machines
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
