Question about Konica Minolta Office Equipment & Supplies
How to solve C-265B error occurred in Konica Minolta ZeusS_ZX0 mfp
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
jqsababa967
  • 145 Answers
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Posted on Sep 20, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
Hi device does not copy C450 Konica K- error gives FB52
Error concerning Data transmission Bus or hardware (IR
Input system) Check connections between the MFP Control Board (PWBMFPC) Copier Board (PWB-CF) Some serious money so check all connectors, remove them one by one and check each one for bent pin(s) ensure reseated properly, could also have bad firmware, requires tech, because firmware is on secure web site at Konica Minolta.
Aug 21, 2015 | Genuine Konica Minolta Konica Minlta...
When turn on the machine the error code c-c170 indicates
NVRAM and or MFP Board failure. Recommended you get a qualified Konica Minolta Tech out to correct. as The Firmware for the machine may need to be re-flashed. The firmware is at a secured website, for Konica Minolta Technicians. The board might also be bad. the NVRAM is memory that stores major info on the copier. The code is telling you not enough memory for the MFP board or that the MFP board is having issues. MFP are not cheap$$$$$$$$$$$$$$$$$$$.
Jun 11, 2015 | Konica Minolta Bizhub c203 Copier
Bizhub C450 has error code C-F023
CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job
Aug 23, 2014 | Konica Minolta bizhub C450P Laser Printer
Why C-FA14 error came in C364e Model MFP?
Any of the following boards may have gone bad. This Series of codes are call abort codes. MFP, Dual Scan Image Processing Board, Memory #1 and Memory#2. Recommend you have a qualified Konica Minolta Rep look at this problem
Jun 19, 2014 | Konica Minolta Office Equipment & Supplies
C451 reset errore c-c172
• A dynamic link error occurs in the program
on the MFP board due to an insufficient
memory space available, a ROM fault, or
other reason when the main power switch is
turned ON.
have tech come out might need to have the firmware re-flashed or the MFP or image control board replaced, have the Memory checked also $$$$$$$$$$$$$$$$$$$$$
May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
THE KONICA MINOLTA C360 COPIER SHOWS ERROR CODE C6103
• Scanner home sensor (PS201)
• Scanner motor (M201)
• Scanner relay board (REYB/SCAN)
• MFP board (MFPB)
Scanner is located under the big glass. reset open close right door
Jan 21, 2014 | Konica Minolta Office Equipment & Supplies
Error code c-fb58
Hi Wazza,
CFB58 relates to an internal bus error on the MFP control board. To reset you simply turn the machine on/off (main swithc inside front door) If the fault reoccurs, you may need an engineer to flash your firmware/replace the MFP control board.
If it's the latter, I suspect it will be more cost effective to replace the machine. Average cost of a MFP board for your model is £1200.00
Hope this helps
Regards
Taminol
Apr 17, 2009 | Konica Minolta bizhub C250 All-In-One...
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
