Question about HP Computers & Internet
Hp 8000 Solid Red light
Hp 8000 sff Solid Red light but computer boot and run fine with no error message or problem i tried to reset all cables, change ram,hard disk.
  • HP Master
  • 1,497 Answers
Desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
hp 8000 Solid Red light - sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
Posted on May 05, 2017
Testimonial: "FRONT POWER LED SHOW RED WITHOUT ANY BLINKING BUT SYSTEM BEHAVE NORMAL. I THINK ITS A BUG OR SOMETHING"
  • 1 more comment
  • Larry Ng
    Larry Ng May 06, 2017
    ask at hp forum.
    this lamp means error.
    and solid glowing is not in the manual
    why not ask on real forum for HP>?
    it might be fans dead? or other important reasons. or fans too low rpm
    or overheating.
    ask on the real forum , hp.com per links above.
  • Larry Ng
    consider this, maybe the last updates to the system BIOS,added new warnings, ask hp.
  • Anonymous May 22, 2017
    when i see warnings, i use black tape to hide them. makes life, exiting.
    ever heard of HP.com?
Hp compaq computer is showing a red light and stop booting
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Jan 09, 2013 | HP Compaq d530 SFF PC Desktop
I try turning on my hp compaq d530 sff this morning it did not boot and the switch light was blinking red every two or three seconds.
PLS REMOVE THE POWER CORD AND THE BATTERY FROM YOUR LAPTOP AND WAIT FOR 5 MINS THEN RE-INSERT THEM AND ON IT . SHOULD WORK
. PLS REPLY OR COMMENT. THANKS
Jun 15, 2011 | HP Compaq d530 SFF PC Desktop
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Hp compaq d530-sff issues
These are network boot cards, basically it's looking for boot options from across your network. You can change the boot options in your BIOS or there is usually a key combination to press that is displayed on screen during boot to shut of the PXE boot of your network card.
May 06, 2010 | HP Compaq d530 SFF PC Desktop
I have an HP Compaq dc7600 sff that will not power on. It has a solid green light on motherboard, no other response.
1) perform a powerdrain i.e. unplug the power cable from the back of the computer and then press power button and hold it down for 10 secs
2) open up the chasis and reseat the power cable i.e ATX connector coming out of the SMPS to the motherboard
Feb 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
I have an HP D530 SFF and have a similar boot issue as another person on this forum. When I turn on the computer it acts like it is going to boot and then goes to a black screen with an underscore blinking...
do you reach the manufacturers logo such as Dell logo when you start up your computer? if none, then you may have a POST problem. Ttry to re-seat the ide/sata cables and ram.
Dec 16, 2009 | HP Compaq d530 SFF PC Desktop
Memory card error on hp psc 1610
it is a logic card problem.so you can checked it from vendor.
Aug 16, 2009 | Office Equipment & Supplies
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
Will not boot up
The beeps are error codes there should be a system what it sounds like is 3 beeps then a pause and it starts again. go to www.support.hp.com and click on drivers and downloads then type in your model number and download the manuals there will be a chart stating what the beep code means if you have a warranty go to the liive chat and just have there technicians tell you what it means to save time then repair the error
Aug 20, 2008 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
108 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
