I am looking for a thermostat manual for a lennox central heating its an older unit thanks in advance
  • Heating & Co... Master
  • 1,874 Answers
There's 100s of Lennox units and 1000s of tstats. What are the model numbers
Posted on May 05, 2017
Testimonial: "unfortunately I do not have a model number it is a basic thermostat control with a hold button a select button and two arrow buttons"
  • Thomas Woodburn
    Thomas Woodburn May 13, 2017
    Lol. What is it that you are trying to figure out? Possibly I can help!
Does a y2081 lennox thermostat have a batteryin it
Yes it has 3 AAA batteries.
Pull it straight off the wall. Look at the back of the thermostat and replace the three batteries.
Link to manual..
http://www.lennox.com/pdfs/manuals/Lennox_Elite_Touchscreen_Manual.pdf
Sep 10, 2014 | Lennox Y2081 ComfortSense 7000 Thermostat...
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
I have a Lennox CB19-51-1P and it runs constantly but is only putting out about 64 degree air when the thermostat is turned up all the way
Not sure if you are heating or cooling.... but either way if the unit is not getting the proper air temperature and it is continuously running then the first thing I would look for is a freon leak...the unit is undercharged and the leak needs to be fixed and then the unit charged correctly...
From the model number of the unit I think it is an older unit and straight A/C ... if the indoor temps. are 80 or more the 64 could be okay... but if the indoor temps are in the mid 70's then it is under achieving...
You should get 15 to 20 degree temp. drop across the coil...
heatman101
Dec 19, 2010 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
LOOKING FOR MANUAL FOR LENOX AIRCOND. UNIT LGA
email me and I can send you a copy of the Lennox Service manual. www.emshvac.com
Oct 30, 2009 | Heating & Cooling
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
