Question about Exercise & Fitness
What is IGF-2?
Medicine
    New Friend:
    Problem Solver:
  • 8 Answers
Insulin-like Growth Factor-2, also known as somatomedin A, is another important growth factor of growth hormone. IGF-2 has been found to be an important modulator of muscle growth, helping to stimulate the maturation of dormant new muscle cells. It is also involved in the health of the brain, nerves, liver and kidneys. IGF-2 is also a mitogen for many types of normal cells. There are sites where you can get more details.
Posted on May 05, 2017
Which form is powerful for taking IGF-1 LR3?
The LR3 form features a half-life of twenty to thirty hours and it's more powerful than the typical IGF-1 peptide. LR3 will act in the body for a full day, more or less, and bind to receptors within cells, thereby spurring growth and inspiring weight loss. So, it should be injected into the area that you want to grow! DES is the best choice for long-term injections. To get the details you can look on a peptide.
May 02, 2017 | Health & Beauty
Where can I find IGF-1 Peptides?
A lot of online suppliers offer authentic IGF-1 peptides. When you choose it you must take care of the purity of the product which is authentic. The LR3 form features a half-life of twenty to thirty hours and it's more powerful than the typical IGF-1 peptide. To get more details you can click on Insulin-like growth factor peptide.
Toyota Camry 1990 V6 2.5L obd1 codes 11 and 14 Check Engine Light on. Codes 11 and 14. Hooked up a good pulled hopefully ECU and check engine light came on again after driving 1/5 of a mile.
code 14 - ignition signal. No IGF signal to ECU 4-5 times in succession.. need check: • Ignition circuit (+B, IGT, IGF) • Igniter • ECU
Jan 03, 2017 | 1990 Toyota Camry
Toyota p1300
Error Code: DTC P1300
Description: Igniter Circuit Malfunction
Solution:
To repair the code please do the following:
1. Check spark plugs.
2. Check for open and short in harness and connector in IGF (Ignition Confirmation) signal circuit between ECM and igniter.
3. Disconnect igniter connector and check voltage between terminal IGF of ECM connector and body ground.
4. Check for open and short in harness and connector in IGT1 - 3 signal circuit between ECM and igniter.
5. Check voltage between terminals IGT1 - 3 of ECM connector and body ground.
6. Disconnect igniter connector and check voltage between terminals IGT1 - 3 of ECM connector and body ground.
8. Check for open and short in harness and connector between ignition switch and ignition coil, ignition coil and igniter.
9. Check and replace ignition coils with a good known one.
10. Check and replace ECM with good a known one .
Hope that works.
Thank you for visiting Fixya.
Apr 06, 2014 | 2001 Toyota Corolla
Starts and stalls
Check the ignition confirmation signal (IGF) on igniter number 1 and pin number 2 during cranking. Look carefully if any wire is broken at any of the igniters 1,2,3 or 4.
Nov 13, 2013 | 1999 Toyota Corolla
Toyota corolla 1997 engine code p1300 ignitor circuit malfunction #1 car starts after 2 minutes will stop
Error Code P1300/ 14. Igniter signal malfunction No.1
Problem Areas:
IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
--IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--IGNITION AMPLIFIER/ DISTRIBUTOR.
--ECU
Oct 18, 2013 | Toyota Corolla Cars & Trucks
What are some specific types of medicine balls?
Some of the varieties of medicine balls include: leather medicine balls, soft gel medicine balls, medicine balls with grip, air filled medicine balls medicine balls with handles and medicine balls with a rope attached.
Aug 05, 2012 | Exercise & Fitness
No start, P1300 code, new distributor, coil, igniter, plugs, and wires
Check First the crankshaft sensor.2 Coil new one.3 IGF
Aug 31, 2011 | 1997 Toyota Previa
How do you feed and water the fouls or give them medicine? This is for the DS (not wi-fi). The foods and the medicine is all grey
fouls like grasses very much ..tyake some amount of grasses in your hand crush it then keep medicines in between those grasses and give it to horse
Jun 08, 2010 | Ubi Soft Entertainment Petz: Horsez 2
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
