Question about Canon Office Equipment & Supplies
HOW TO RESET CANON IR 2204 ERROR E002-0000? - Canon Office Equipment & Supplies
    Habit-Forming:
    Scholar:
  • 103 Answers
Service Mode Entry
1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
2. Press 2 and 8 on the keypad at the same time.
3. Press the User Mode key on the control panel.
If done correctly the display will read
COPIER
FEEDER
SORTER
FAX
BOARD
Press the Copier Icon
Press the Function Icon
Press the Clear Icon
Press the Err Icon
To exit service mode : Press the Reset key twice to end service mode and return to the User screen
Posted on Nov 17, 2017
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
How to remove error code e000-0000 in canon ir 2204
1. In standby mode,press the "Settings/Registration" key.
2. Press the"Reset" key.
3. Press the"Back" key.
4. Press the"Settings / Registration" key.
5. The service modescreen is displayed.
6. Scroll to Printerthen choose Clear
Use the"Back" key to exit Service Mode
Jan 02, 2018 | Canon Office Equipment & Supplies
HOW TO RESET CANON imageRUNNER 2204 e000-0000 this edition does not have a keypad as described in one of the solutions given but it has a touchscreen!
Try this im not sure if this same for canon ir 2202
1.press the setting key
2.reset key
3.back key
4.setting key again
take a look on display go to copier then go to function the clear..
Good luck.
Dec 28, 2017 | Canon Office Equipment & Supplies
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Dec 26, 2017 | Canon Office Equipment & Supplies
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
807 people viewed this question
old marine
old marine
