Question about HP Office Equipment & Supplies
30.20.00 jam in top cover hp p3015 printer - HP Office Equipment & Supplies
SOURCE: paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Posted on Jan 17, 2008
  • 398 Answers
SOURCE: 13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Posted on Jun 23, 2009
  • 105 Answers
SOURCE: Our HP Color Laser Jet 4700 dn frequently gives an
There is either a small piece of paper in your paper input section or you have a paper sensor going bad.
Posted on Nov 20, 2009
Catzy87
  • 10 Answers
SOURCE: I want to reset my
Press the Menu button c01779038.gif , select the CONFIGURE DEVICE menu, and then select the RESETS menu. RESTORE FACTORY SETTINGS. Clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Hope this helps.
Posted on Aug 06, 2011
seeker5211
  • 1089 Answers
SOURCE: i have 5200 hp laserjet printer is a problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
tray settings and the dial on the tray.
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Posted on Oct 28, 2011
How do you remove paper stuck in the back of a P3015 printer?
If the paper is jammed in the fuser, sometimes the only safe way is to remove the back door to gain better access. Open the back door, on the right side you will see a white arm that attaches to the door and disappears into the printer. Pop it off the shaft if is clicked to. Then remove two screws from the back door. Lift the lower panel that covers the paper drawer and pry on each side of the lower back door. Once those catches release, pull the back door off by pulling the bottom of the panel towards you and the top will pop out. When reinstalling the door, make sure to reattach the white arm to the door before closing the door. Failure to do that can result in that arm getting broken,.
Oct 13, 2016 | HP P3015 Laser Printer
P3015 hp lasser printer 49.4C01 error proper solution
Sounds like a bad formatter. I would try a firmware upgrade first and if unsuccessful, would replace the formatter. These formatters are infamous for failure.
Feb 22, 2015 | HP RB1-3015 LaserJet 4L Laser Scanner...
How do I fix the "phantom" paper jam on HP P3015?
Just had one today that would throw a open rear door error. Turned out that the flag in the back of the fuser was dislodged.
Sep 29, 2014 | HP Office Equipment & Supplies
How do I fix the "phantom paper jam on P3015?
Do you have an error code? Usually if you get a jam error and there is no paper in the printer it is because the printer was unable to pick the paper out of the tray. Try printing from the drop down manual tray to confirm that the printer itself works. If it does, then clean the roller in tray 2 with a damp cloth and make sure you dry it completely.
Sep 29, 2014 | HP P3015 Laser Printer
59.30 error intermediatly in HP P3015
fuser motor startup error, possibly fuser is bad
Jan 09, 2014 | HP P3015 Laser Printer
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
Hp laser jet p3015 not powering on
41.2 error hp laser p3015 printer
Mar 25, 2013 | HP Laserjet P3015X Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
