Question about Samsung Cell Phones
Xgody k109 wont make ph calls no dial tone strong signal can connect online but cant make or recieve calls sim works fine in samsung phone
  • 31 Answers
Is it in airplane mode?
Posted on May 06, 2017
  • 15 Answers
SOURCE: No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Posted on Jan 29, 2008
  • 1214 Answers
SOURCE: FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Posted on Jan 26, 2009
  • 40 Answers
SOURCE: Modem connects to internet but I have no dial tone to make calls
I have personally seen this issue before and with an Arris cable modem the issue you are having means that there is a over current issue with your phone line. What this means is that your phones are either getting to much or to little voltage. Usually this is caused by a crossed phone wire/staple through a phone line or possibly corrosion on your line. The first step into troubleshooting this would be to check where your phone lines tie together at and make sure nothing has come loose or broken. Also if you any of your lines run outside to a phone box go in the customer side of that and check to make sure there is no corrosion. This can also be caused by a phone going bad. Go around and unplug your phone lines 1 at a time from the phone line and see if it starts responding correctly. You made need to power cycle/reset your modem when you do this to clear the error. The final way that you can tell if it is in your phone line or not is to unplug the modem from your house line and plug a phone straight into the modem. This should make at least that one phone start working correctly.
Posted on Apr 09, 2009
Bajanguru
  • 7752 Answers
SOURCE: No dial tone at my end when I ring a certain number even though the number I'm calling is ringing, also really slow to connect. all other numbers are fine
dial tone but mobiles ahve no dial tone when making or receiving calls.....
Posted on May 30, 2009
SOURCE: Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
I disconnected my incoming phone line and connected my VOIP line 1 to my R11 wall phone jack. This feeds the signal to all phone jacks in the house.
I also use the VoIP to fax and send data using my PC modem.
For Fax
Use *99 as a prefix for any number you are faxing or dialing to.
Dial-up
1. Configured area code dialing rule in Phone
Posted on Sep 11, 2010
My samsung galaxy proclaim will not let me make calls {not registered in network} cant send texts or recieve text says no signal found for mobile networks no network connection . facebook works fine
Hello Kay
Your smartphone is two devices in one.
1. A phone that makes calls and sends text messages via over air signals via a cellular provider on a contract or pay as you go.
2. A device that can access the internet in two ways
2a. via your cellular carrier using a data plan.
2b. via a wifi connection using someone else's internet connection.
So yes, Facebook works fine via wifi, but you have no cellular network set up. Contact a cellular provider, sort out a contract and they will give you a SIM card to put in the phone and then your calls, text and data will work.
Jan 04, 2017 | Samsung Cell Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I cant receive fax
Is there a dial tone if you pick up the reciever ? Can you send faxes or use the machine to make a phone call ? If you can make calls or send faxes the machine probably needs to be set to the auto recieve mode so that it automatically answers when a fax is being recieved. If no dial tone you may have a loose connection to your phone jack.
Oct 15, 2010 | Kodak 6150 AllInOne InkJet Printer
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Have just bought a used samsung prostar 816 stc phone, but can't
Possibly, does the system shut the line down or does it just doesn't break dial tone?
Mar 25, 2009 | Samsung Prostar 816 Phone
Cant make or recieve calls
Take the SIM card out and re-install it. You may need to call your phone provider and have them unlock the phone.
Good luck.
Mar 19, 2009 | Motorola Mobility RAZR V3
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Cell Phones Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
