Question about Whirlpool Dryers
My Whirlpool Dryer is flashing E6 & F3 and the dryer wont work.
  • 113 Answers
SOURCE: WHIRLPOOL DRYER GGW9200LW1 My whirlpool GGW0200LW1 dryer stopped
Reach inside and try to turn the drum by hand, it should have some resistance, if it spins free, you may have a broken belt or it fell off. There is a switch on many dryer that is attatched to the motor. If the belt breaks it triggers the switch which disables the motor and heater on the dryer. Also double check that model #, Im not finding anything under that #. thanks Dave www.washermd.com
Posted on Dec 16, 2008
SOURCE: whirlpool dryer
sounds like stuck brushes in the motor (bad motor)
Posted on Dec 17, 2008
  • 13 Answers
SOURCE: dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Posted on Dec 19, 2008
  • 289 Answers
SOURCE: i have a whirlpool tumble dryer awz3518, that has
run the dryer with out the vent hose hooked up.if the dryer work's than you have a problem with the vent system.check your vent hose from the dryer to the outside vent.
Posted on Dec 29, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
Whirlpool Cabrio elec dryer error code f3 e1
Michael, We are sorry to hear about your Dryer giving an error message. We would recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Dryers
Whirlpool 6th sense dryer my clean filter light keeps flashing and the dryer wont work
replace the lint filter sensor reid switch and it will work fine
merry christmas
Dec 22, 2010 | Dryers
Dec 16, 2009 | Whirlpool Dryers
Our Whirlpool Duet dryer won't run. After selecting a cycle and pressing the start button, it beeps twice and the time flashes. what can we do to fix this?
Make & model # please. When the "time flashes" are you sure it is the time or is it an error code like F3 or maybe F10? Please advise.
Oct 08, 2009 | Whirlpool GEW9250 Electric Dryer
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
Dryers Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
