F3 & E6 codes on dryer - Computers & Internet
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error code F1 F3 F6
KitchenAid Fault Codes - AppliancePartsPros.com
www.appliancepartspros.com/repair-help/kitchenaid-fault-codes.html
Jump to Kitchen Aid Range / Stove / Oven Fault Codes - Failure Code, Fault CodeDescription, Solution ... F1 - E6, Latch signal mismatch error ... F3 - E0, Oventemperature ... electronic control will display F6 ...
Jan 27, 2016 | Kitchen Ranges
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Eurovox codes may 10th 09
Try these:
C/W 5c-01 May 7th 2009
key 00 = A7 B2 EE 5F 9D D8 69 0E
key 01 = 3D 82 E6 58 8E 0D B3 62
T/W 5a-01 May 7th 2009
key 00 = AA B7 D1 D9 CE 8E 83 AF
key 01 = 8E 80 D7 EF 44 93 02 2B
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
IRELAND NTL 54-01
KEY 00 =B0 B8 4F 04 E6 5F 87 80
KEY 01 =A3 EB EC 07 D6 49 D2 EB
IRELAND CHORUS 5E-01
KEY 00 =CE 19 2E 87 80 61 74 90
KEY 01 =62 FA D9 F3 CE 05 FA 79
May 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX CODES
hi try these codes
00- b0 b8 4f 04 e6 5f 87 80
01- a3 eb ec 07 d6 49 d2 eb
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes Dec 18th
NTL DUBLIN THURSDAY 18TH DECEMBER 00 Code - B0 B8 4F 04 E6 5F 87 80 01 Code - A3 EB EC 07 D6 49 D2 EB Have fun ****
Starview code
ANYONE GOT CODES FOR STARVIEW TELEWEST 11/7/08 PLZ
Jul 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Need codes
5C01 23/4/09
0B F2 52 72 4E 1B 86 90
Jun 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
